Lamin-X tailight covers?
RIPjeep2002
Yes. I've got them on my car (all rear lights and the '08+ reflectors) and love them. Plus, having seen several other LGT buddies of mine use standard window tint and have endless problems with wrinkles I'm glad I spent the cash. Be forewarned though - the third (fourth?) brake light cover for the spoiler wasn't cut right so they had to send me a bulk sheet that I cut myself.
Not very - they're really forgiving during application. Just make sure you get it right 'cuz once they dry out it's a done deal. Use a hair dryer or a heat gun to soften up places that don't seem to want to fit correctly or to "lock" down an area. The instructions have lots of good tips. One thing I forgot to do while applying mine was keep the outside of the film wet so I've got some minor scratches on the surface of the film from the applicator.
Honestly it sounds harder then it actually was, just take your time and follow the instructions. You may also want to heat the film up a bit with a hair dryer just so that it is flexible when your trying to put it on.
It is not that hard... Make sure when you are applying you peel off and reapply as many times as you need to; I must have pulled corners off and put it back on at least 20 times to make sure it was aligned correctly.
Hair dryer, also very handy.
I have been a dealer for them for ahwhile (not trying to solicit) But the kits are the easiest to install you can find. They are much thicker than tint or anything else which makes them pliable and flexible. If you read the entire directions before starting, you should have no problem getting them on.
Do you all have a sponsor on the forum that sells them already? If not i may consider it, if someone can send me to the correct person.
-Chris W
-Chris W
Yes, we have a sponsor already, Andrew (AJW Performance if I remember correctly) who I bought mine from at a good price. Good guy. He has his own thread in the Vendor Classified section.
Would it be easier to remove the tailights than apply the film
Absolutely NO NEED to do such a thing.
People really need to start using the SEARCH function before starting threads... Please people, it saves you time, saves us time, and makes the world a happier place.
Check out Andrew's vendor thread here:
http://legacygt.com/forums/showthread.php?t=71215&highlight=lamin-x
Pics from my install here:
http://legacygt.com/forums/showthread.php?t=71215&highlight=lamin-x&page=25
Gotch, saw your post there, for future referencethe easiest way to cut it is with a new blade, score it where you want it then go over the score multiple times to get a clean cut. Most people try to slice the whole thing on one try... doesn't work out too well.
