95 subaru swap question
the 95 being obd2 doesn't mean anything. If you swap a different motor you need the ECU and wiring to go with it.
You are actually better off with the 95 because it doesn't have to conform to all the emissions sh!t. You can put an obd1 motor and ECU in and be fine, whereas if you put a obd1 system in a 96+ car you'd never pass inspection.
^ yes correct the impreza was OBD-I and to read codes you needed to connect the two green cables under the dash.
the Legacy I have which is a 95 has the OBD-II port and has the same two green connections under the dash.
I have the same thing, when I connect mine, all the relays click on and off and the CEL flashes steadily. And if I read it with an OBDII reader I get nonsense codes, like 11 of them and none of them are related. I've heard its some sort of diagnostic mode and that if you have a subaru specific reader you can pull some information in that mode that you can't normally get.
I ignore it for the most part though.
