Mindspin311 Posted April 4, 2009 Share Posted April 4, 2009 Trying to visualize how I think the different exhaust pieces go together, I just dont understand how raising the motor helps get the up pipe out. Anyone care to explain? Link to comment Share on other sites More sharing options...
itsme Posted April 4, 2009 Share Posted April 4, 2009 you don't have to raise the motor. Just take off the pass. side manifold and take out the bottom or take ff the turbo and pull it out the top. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
whitetiger Posted April 4, 2009 Share Posted April 4, 2009 if you leave the egt sensor in the UP, you cannot slip it out from the bottom unless you raise the motor. if you just remove the sensor, or bent it out of the way, you dont have to raise the motor and can slip it out the bottom after removing the headder on the passenger side. Link to comment Share on other sites More sharing options...
