Explain something to me. (7.5" vs 7")
Daedalus
Whats the point of going to a 7.5" wide wheel? You can mount 225s on a 7" wide wheel so whats the point of going to 7.5"? According to Xenonk's guide, 235s are not recommended for 7.5" wheels, so whats the point?
From reading his posts, the max we *should* run on a 7" wide rim is 215.9mm or 215, which is 1.5" over the width of rim. For performance, 1" over, or 203.2mm, or 205mm. So if 7" width, 8.5" tire width should be your max. Any thing more than that would result in flex on the tire sidewall.
IMO 235's on a 7.5 rim would not be so bad as long as you got a tire with a relativly stiff sidewall construction. 245's on a 7.5 rims is way too much. IMO 235 on a 7,5" rims would be like 225's on a 7" rim, and as we all know, many people put 225 tires on the stock 7" rims.
I'm running 225/35/19 on 7.5 and tires fit perfect. It also depend on who makes the tires. When I had falkens the tire looked like the where too narrow for the wheel. It looked like the where streaching. But,with the General the tread is wider and side wall is flat with the rim. http://i167.photobucket.com/albums/u156/itsmebryan/124755.jpg
http://i167.photobucket.com/albums/u156/itsmebryan/112332.jpg
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
