ConeEluder Posted April 3, 2009 Share Posted April 3, 2009 So I bought a STI uppipe off craigslist for $40, couldn't pass it up. Problem is, like most other STI uppipes one of the studs is broken. Why is that? Every STI uppipe I've seen has had one broken stud. Anyways... How can this be fixed/replaced? Can I remove a stud from my catted uppipe and use that on the STI uppipe? Also - the heat shield welds have broken. People suggest rewelding them instead of removing the heat shields. Why? How's it any different than an aftermarket uppipe? Thanks in advance. Link to comment Share on other sites More sharing options...
black318i Posted April 3, 2009 Share Posted April 3, 2009 A stud from your old up will work, but they are a pain to remove sometimes. As far as the heat shield I don't see an issue if you remove it. Most aftermarket ones don't have a shield. Link to comment Share on other sites More sharing options...
korpsepatrol Posted April 3, 2009 Share Posted April 3, 2009 I don't know if you have any pics up since i am at work but you would need two bolts and you would place them on the broken stud. Then loosen the one on the bottom and tighten the one on the top of the stud. After that is set, you take another wrench and twist both at the same time so that the stud acts like a screw your loosening. You will need a crap load of pb blaster. Also you could always do the heat up with blow torch and cool down with cold water trick which makes the loosening a bit easier. I forgot the technical term for it, welders might know. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
ConeEluder Posted April 3, 2009 Author Share Posted April 3, 2009 Thanks, I figured it was possible I just wasn't sure. I'd like some more input on the heat shield as well - I can't see any problem with removing the heat shield myself. Link to comment Share on other sites More sharing options...
dazzen Posted April 3, 2009 Share Posted April 3, 2009 Keep the shield and add lots of welds so its stronger!....they have heat shields for a reason. Link to comment Share on other sites More sharing options...
ConeEluder Posted April 3, 2009 Author Share Posted April 3, 2009 Keep the shield and add lots of welds so its stronger!....they have heat shields for a reason. See, that's all everyone has ever said. I've never actually seen someone say what that reason is. Link to comment Share on other sites More sharing options...
black318i Posted April 3, 2009 Share Posted April 3, 2009 Out of all of the aftermarket UP's made only 1 has a heat shield. I've never heard any issues other than fit so I'd say it's safe to take it off. Link to comment Share on other sites More sharing options...
dazzen Posted April 4, 2009 Share Posted April 4, 2009 It wont make any BIG difference what you do...but the "only" real advantage in removing the shield is to prevent future cracks in the welds which will cause rattles. Either re-weld & add more welds to prevent future rattling or take it off...which ever is easier for you. Link to comment Share on other sites More sharing options...
AShoe Posted April 6, 2009 Share Posted April 6, 2009 In general heat shields are there to reduce radiant heat under the hood. Also they reduce energy lost by the exhaust on its way to the turbo. More heat means more exhaust volume. So the hotter the exhaust is when it reaches the turbo the faster it will spin. With a TMIC some of the heat lost by the up pipe may raise the temperature of the intercooler and reduce its cooling capacity. That's a very basic overview of the reasons to have heat shields. So leave them if you can. Header wraps can cause rust so unless you have stainless parts they are not a good substitute. Coatings like grimmspeed puts on also work on this principle. Link to comment Share on other sites More sharing options...
