A few AP logs..
trademark
I'm stage2 with an OTS Cobb map. I am going to get a Tactrix cable by May but I thought I'd throw these up. I am still reading up on the data part but I think I did this right.. the last two logs I added all the available perameters.. the DA numbers look different than some of the other logs I've seen on here.. but maybe thats the Cobb tune.. :confused:
thanks for any input.
1st-3rd WOT.csv
1st-3rd WOT2.csv
1st-3rd WOT3.csv
2nd-3rd WOT9.csv
im not an expert but i know one thing is a fact. your logging way to much parameters and you should just be doing a 3rd gear pull from 2000rpm to redline.
+1
log these:
Engine Speed
Engine Load (1 byte)
Total Timing
Knock Sum
Turbo Dynamics Integral
WGDC%
Manifold Relative Pressure (corrected)
Maf g/sec (I don't think this is needed, but I ike to log it)
Throttle position %
2000-redline in 3rd gear
