Max Capacity Posted March 31, 2009 Share Posted March 31, 2009 A good friend of mine had to have her cat replaced 05 Outback 2.5i Limited. The Dealer covered the job, 78,000 miles. Before she always got less then 24.3 mpg normally she's in between 21 and 23mpg. Since the new cat, she now see's 25 + mpg. Nothing else has changed. Has anybody else noticed a increase in mpg after replacing the OEM cat with a new one? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
987687 Posted March 31, 2009 Share Posted March 31, 2009 were the O2 censors bad too? if they were, that would probably be the main reason the gas mileage increased. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 31, 2009 Author Share Posted March 31, 2009 As far as I know only the cat. I've heard of other people on here that get low mpg. I wonder if they had bad cat's or bad O2's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mikeislord Posted April 1, 2009 Share Posted April 1, 2009 I would have assumed O2 sensors as well. Link to comment Share on other sites More sharing options...
987687 Posted April 1, 2009 Share Posted April 1, 2009 I'd assume that o2 censors are part of a cat. kit and that they wouldn't re-use the old ones. But ya never know... Link to comment Share on other sites More sharing options...
Max Capacity Posted April 1, 2009 Author Share Posted April 1, 2009 I'll have to see if she if knows if the O2's were replaced too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
987687 Posted April 1, 2009 Share Posted April 1, 2009 They may also have flashed some updated firmware onto the ECU that improved the gas mileage. Link to comment Share on other sites More sharing options...
silbeej Posted April 1, 2009 Share Posted April 1, 2009 Only thing i'm wondering is do cars get lower MPG as they age, or does it go up? But it was probably the O2. Link to comment Share on other sites More sharing options...
987687 Posted April 1, 2009 Share Posted April 1, 2009 Only thing i'm wondering is do cars get lower MPG as they age, or does it go up? I get 31mpg on my 1996 legacy. Link to comment Share on other sites More sharing options...
boosten-n-bluntin Posted April 1, 2009 Share Posted April 1, 2009 a new cat flows more air the more air you can flow the more hp and mpg. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 1, 2009 Author Share Posted April 1, 2009 Only thing i'm wondering is do cars get lower MPG as they age, or does it go up? At 105,000 miles my 05 is getting more mpg then 5 years ago. But I also drive differently now. I'm focused on using less gas and sticking it to OPEC. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
