c-lo Posted March 31, 2009 Share Posted March 31, 2009 there are COUNTLESS threads on this issue and rather than search through those threads I thought I'd post my question here. Have we are is there any explanation as to why the stock bulbs repeatedly burn out? I just replaced a bulb 2 weeks ago and the damn thing blew out again last night. I've very careful when I install them so I'm going to rule that out. My dome lights repeatedly burn out too and have yet to hook up a volt meter to them. I've got to wonder if the two issues are related. When I replaced my low beam two weeks ago the bulb I took out looked like it was about to burst. the bulb had a bubble on the side of it. I'm about ready to drop some $$$ on some HIDS. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
zcarmob Posted March 31, 2009 Share Posted March 31, 2009 When you installed the headlights did you touch the glass on the bulb. I'm pretty sure that the grease on your fingers will cause the bulb to fail prematurely. Link to comment Share on other sites More sharing options...
c-lo Posted March 31, 2009 Author Share Posted March 31, 2009 As I stated I'm very careful when i install them, so that can be ruled out. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
bluesuby Posted March 31, 2009 Share Posted March 31, 2009 Are you starting your car with the headlights "on"? I believe that was discussed in an earlier thread. Link to comment Share on other sites More sharing options...
c-lo Posted March 31, 2009 Author Share Posted March 31, 2009 daytime runnings lights unplugged. lights turned off before car is turned off. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
suzysube Posted March 31, 2009 Share Posted March 31, 2009 H7's are known to have a short life span. Mine have surprisingly lasted for almost 2 years. So i don't know whats going on with yours. I'm interested to see what the problem and outcome is. Link to comment Share on other sites More sharing options...
Levish Posted March 31, 2009 Share Posted March 31, 2009 Check to make sure you have all the pop-its and rubber grommets around the headlight housing. I was having blubs going out all the time, and it seemed like in particular they went out after bumps and it was always the same side. I was missing a pop-it on one of them, i replaced it and haven't replaced a bulb in about three years knock on wood. Link to comment Share on other sites More sharing options...
c-lo Posted March 31, 2009 Author Share Posted March 31, 2009 I'll check, however as many times as I"ve been in i haven't noticed anything 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
speddmn Posted April 1, 2009 Share Posted April 1, 2009 redundant and dumb maybe but make sure you're getting your cup-cap thingies on right, i x threaded mine in a hurry, twice and went through 2 bulbs in 4 weeks.. weren't sealed. Link to comment Share on other sites More sharing options...
Waxiboy Posted April 1, 2009 Share Posted April 1, 2009 HID's...been running Philips D2S and Koito ballasts since 2006 Link to comment Share on other sites More sharing options...
AWDxBOOST Posted April 1, 2009 Share Posted April 1, 2009 ^same...one of my headlights burned out and i was like, w00t...time to upgrade! Link to comment Share on other sites More sharing options...
whitetiger Posted April 1, 2009 Share Posted April 1, 2009 upgrade to HIDs = Problem solved. HIDs will prolly last the life of the car. add up all the $$$ you spend on bulb replacement, and the HIDs become well worth it especially when you can get set now for around $100 Link to comment Share on other sites More sharing options...
