blue dragon Posted March 30, 2009 Share Posted March 30, 2009 So I went to wash the LGT this weekend, and the sunroof glass is shattered, I don't mean chipped, I mean completely shattered. I found one used, but now I need to know how to change it. Vacation pics says to check something that I couldn't find in the rest of the documents. Anyone have a DIY or can point me in the right direction? Link to comment Share on other sites More sharing options...
gotsugg Posted March 30, 2009 Share Posted March 30, 2009 Where did you find a used one? Link to comment Share on other sites More sharing options...
MOMSWGN Posted March 30, 2009 Share Posted March 30, 2009 The front section is a couple of bolts and two shims. The rear section should be the same (more bolts though) You want to r&r just the glass, don't need to mess with the carrier mechanism. Link to comment Share on other sites More sharing options...
rao Posted March 30, 2009 Share Posted March 30, 2009 What kind of oil are you usinig - I heard that some of the cheaper domestic oils can cause this sort of problem. Also, what is your OIC? And people say that I am not helpful Good luck. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
blue dragon Posted March 31, 2009 Author Share Posted March 31, 2009 Where did you find a used one? http://www.car-part.com I am in Canada, got the glass from a recycler in Quebec for $120 shipped What kind of oil are you usinig - I heard that some of the cheaper domestic oils can cause this sort of problem. Also, what is your OIC? And people say that I am not helpful Good luck. Thank you sir! BTW, what motor did you swap into your E36? Link to comment Share on other sites More sharing options...
rao Posted March 31, 2009 Share Posted March 31, 2009 6.6 liter LS2 Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Spec B Posted March 31, 2009 Share Posted March 31, 2009 ^ it's like a V8 Spec B motor. Link to comment Share on other sites More sharing options...
rao Posted March 31, 2009 Share Posted March 31, 2009 Close..... Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
blue dragon Posted April 1, 2009 Author Share Posted April 1, 2009 Got the sunroof swapped. Anyone need a sunroof motor? I got the whole cartridge from the recyclers. If you need a motor, you can have it for free, PM me if you do. Link to comment Share on other sites More sharing options...
