doing-it-the-hard-way Posted March 28, 2009 Share Posted March 28, 2009 Hello everyone. I am new to the forum but would appriciate any help you could give me. I have new to me 1998 legacy GT with the 2.5 motor and 80 thousand miles on it. when I bought it the car had a rough idle. After that I started getting a missfire code on #2 and #4. I have changed the plugs and wires, coil, and fuel injectors on 2 and 4. I have also done a compression check on all 4 cylinders and got 180psi + on all four cylinders. I don't have any vacum leaks. the #2 and 4 plugs are very wet(gas) and sooty(gas) as the #1 and 3 plugs are clean and white as they are brand new. I am running out of idea's, any help would be appreciated. thanks in advance Link to comment Share on other sites More sharing options...
doing-it-the-hard-way Posted March 31, 2009 Author Share Posted March 31, 2009 I finally popped the timing cover and discovered the the drivers side exhuast cam was two teeth off. I found it interesting that it would still have full compression but I'm just happy that it is all sorted out. Link to comment Share on other sites More sharing options...
Shik Posted March 31, 2009 Share Posted March 31, 2009 Glad you got it sorted. Link to comment Share on other sites More sharing options...
eekay Posted April 1, 2009 Share Posted April 1, 2009 Where's the pictures?! My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
