Hesitation 97 LGT 193k miles
Besides a little bit of a rough cold idle the car runs great. The only engine issue is the slight hesitation when the accelerator is first depressed. When I depress the pedal at idle, it hickups, then revs up/accelerates normally with out issue. Is this normal or something that can be remedied.
'15 FB25
Magnatec 0W-20 + FU filter (70,517 miles)
RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where
everything was changed a little less than 30k ago. Besides the slight hesitation, which has around for a little while now, there are no other APPARENT problems : ) However, I do granny the car and it rarely sees over 4k rpm ever....NGK Plat plugs, btw
Also, I run a can of Seafoam in the gas tank every 3k miles
'15 FB25
