How much power??
pkwok4
I just ordered these parts for my stock 06 lgt. What kind of power can I expect for the following mods...
-cobb ap
-cobb short ram intake
-cobb catback exhaust
-perrin downpipe
-perrin lightweight crank pulley
-perrin uppipe
-AVO turbo inlet
-AVO TMIC
Obviously I would have stage 2(ap,dp,cbe) already, would I need to dyno tune it with my other mods that I have? THANKS
^^ Jon at TDC told me that every car he's seen with a CAI runs like 1.5 units leaner than a stock airbox, and stock with a high flow panel filter runs about 1 leaner. Like if the car wants 12:1, the filter setup will run 13:1, and the CAI will be 13.5:1. That's dangerous.
Return the intake and buy an AVO panel filter...you will have much better results...CObb or not...
You will be ok at best using the Cobb Stage 2 map. Since you will have a TMIC, you can run more boost. get a Protune if available, if not have TA or PDX make you a map to tkae in account the TMIC....you can run another lb. of boost with that. GL
Rehab is for quitters.
This might sound pretty dumb but is a protune the same thing as a dyno tune? Getting it tuned is not a problem I live 30 min away from cobb. My other question is that I know the stage 2 only require a ap and tbe, but will my other mods like the tmic, pulley, turbo inlet, intake, uppipe make me more power on top of the standard cobb stage 2 map?
Yep Protune and DYnotune are the same. the TMIC allows you to run more boost. the pulleyy allows for 'quciker' acceleration not time wise just quicker respsonse...I believe..The UP is always good to do. If you have an 05 it really needs TBD because there is a cat in the 05 UP. The intake CAN be tuned for and can add more powaahhh DK about the turbo inlet...someone will certainly chime in.
GL. I am sure it will change the car alot!
