bdickey058 Posted March 16, 2009 Share Posted March 16, 2009 So i put my bov on my car yesterday. I had to make a custome flange for it and it seems to be holding very well. Until i get my recircultin thingy or am able to run it 50/50 i'm vta. Anyways the bov will not sound off untill like 3500 rpm's. and its not loud at all for a vta. I'm kinda sad about it. I have the adjustable thingy turned all the way to soft. Also i can smell that my car is running rich inbetween shifts so yea that sucks. So what do i do. why is it so quiet. It works great and i am actually holding boost a lot better does not die at the top end as much and spools quicker. All this was very noticable using my boost gauge. So what do i do, what do i do? Link to comment Share on other sites More sharing options...
johnAWD Posted March 16, 2009 Share Posted March 16, 2009 Which BOV? If you adjusted it for "soft" it's probably going to open at the first hint of vacuum. How did you fashion the flange? Did you test it with a vacuum pump to see what level of vac is required to open it, compared to the OEM part? John's opinion: Installing a BOV simply for noise is silly. /John's opinion Link to comment Share on other sites More sharing options...
FireB Posted March 16, 2009 Share Posted March 16, 2009 Yea, need to know what kinda BOV you got to make more sense out of your question. VTA is kinda meh, but to each his own. Link to comment Share on other sites More sharing options...
ABP_Tardis_42 Posted March 16, 2009 Share Posted March 16, 2009 besides knowing what BOV you are running, what supporting mods do you have? If you have nothing else done, as many other posts will tell you the amount of noise you will hear is minimal. If you have a tune, intake, and other supporting mods it will be much more apparent. Link to comment Share on other sites More sharing options...
itsme Posted March 16, 2009 Share Posted March 16, 2009 you can put back on your stock bov and get a k&n typhoon intake. You will hear your bov sound and your car will run better. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
bdickey058 Posted March 17, 2009 Author Share Posted March 17, 2009 Its a turbosmart dual port bov. How i machined a flange for it. took measurments and cut it out with a waterjet machine! Also my car is running fine. No hesitation or anything. i bought the bov b/c my i was messin with my top mount oneday and had it laying on the ground and my mom happened to run over it breaking the lil knob that holds a hose in. Also very soon i'm having infamous make me a tune. i will have a panel avo filter, cbe, and gutted downpipe also i have not put a vacuum thingy on it yet to see at what level it opens up at. I have it all the way to soft and it wont open till high rpm's! Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted March 17, 2009 Share Posted March 17, 2009 Try cleaning the POS. Are you using a gasket? Keep in mind that a twin vent BOV is going to be more quiet than others. Under low throttle conditions the primary port routes air back to the inlet tract, in order for you to hear the sound both ports must open and that happens mainly under high RPM WOT shifts. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
bdickey058 Posted March 17, 2009 Author Share Posted March 17, 2009 How do i clean it? just take it all apart? And i'm not using a gasket. I used this sealing stuff that seems to work very well. I'll try to take pictures for you guys! Link to comment Share on other sites More sharing options...
bdickey058 Posted March 17, 2009 Author Share Posted March 17, 2009 ? anyone? Link to comment Share on other sites More sharing options...
jarrod Posted March 17, 2009 Share Posted March 17, 2009 if it's quiet and not leaking I'd say bravo! To clean it i'd probably use some kind of degreaser Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 18, 2009 Share Posted March 18, 2009 you can put back on your stock bov and get a k&n typhoon intake. You will hear your bov sound and your car will run better. Link to comment Share on other sites More sharing options...
itsme Posted March 18, 2009 Share Posted March 18, 2009 it really echoes through the intake. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
bdickey058 Posted March 18, 2009 Author Share Posted March 18, 2009 So i was screwing with the bov yesterday and i think i manganged to make a vacuum leak or something. if i gas on it in 1st then go to 2nd 3rd etc it will like make a crazy sound. like the wastegate is staying open or osmething. idk its werid Link to comment Share on other sites More sharing options...
tingtang Posted March 20, 2009 Share Posted March 20, 2009 So i was screwing with the bov yesterday and i think i manganged to make a vacuum leak or something. if i gas on it in 1st then go to 2nd 3rd etc it will like make a crazy sound. like the wastegate is staying open or osmething. idk its werid like a fluttering sound? could be ur bov not opening up all the way to let the air out so its going back through ur turbo.. .not good if thats what its doing... Link to comment Share on other sites More sharing options...
bdickey058 Posted March 23, 2009 Author Share Posted March 23, 2009 no, not a flutter, its just a horrible boost leak Link to comment Share on other sites More sharing options...
