coredump4 Posted March 15, 2009 Share Posted March 15, 2009 So I have my PC and garage full of detailing stuff, but it's pretty infrequent that I use the PC. However I was doing my spring detailing this weekend, and decided to use the PC to remove some really small (but numerous enough to annoy) hairline scratches on my LGT's roof. However, I couldn't seem to to remove them. I went as far as an orange pad (ie, light cutting) with Meguiar's DACP, which I thought should've made short work of these small scratches... but it didn't. What's the pad & compound combo. best suited for removing hairline scratches? Link to comment Share on other sites More sharing options...
Wang Lung Posted March 16, 2009 Share Posted March 16, 2009 ^ Link to comment Share on other sites More sharing options...
StupidDent Posted March 16, 2009 Share Posted March 16, 2009 Adam's Polishes Swirl & Haze would work pretty well... Make sure you work it enough to break down the products... If that doesn't do it, Menzerna SIP is also a good start. Link to comment Share on other sites More sharing options...
Danase Posted March 16, 2009 Share Posted March 16, 2009 Try our Swirl Abolishers. Polishing pad and speed 6 on the PC should do the trick. I'd start with #2 and finish with #1. Here's a Legacy I did with our Swirl Abolishers and a PC. http://i70.photobucket.com/albums/i115/danase/Detailed%20Vehicles/IMG_2746.jpg Link to comment Share on other sites More sharing options...
Wang Lung Posted March 16, 2009 Share Posted March 16, 2009 Wow. I can almost read the writing on the chalk board. Link to comment Share on other sites More sharing options...
coredump4 Posted March 16, 2009 Author Share Posted March 16, 2009 Adam's Polishes Swirl & Haze would work pretty well... Make sure you work it enough to break down the products... If that doesn't do it, Menzerna SIP is also a good start. You make a good point, b/c when I first started using the PC, I'm certain I was not breaking down the compounds. I am definitely doing that now. How abrasive are the products you listed vs. Meguiar's Dual Action Cleaner Polish (ie, DACP)? One of the things that irritates me about all the different products out there is that it's very hard to compare apples to apples because not all manufacturers rank their abrasiveness. Link to comment Share on other sites More sharing options...
StupidDent Posted March 16, 2009 Share Posted March 16, 2009 sorry... I haven't used DACP so I can't really give you a good reference/advise on that... You make a good point, b/c when I first started using the PC, I'm certain I was not breaking down the compounds. I am definitely doing that now. How abrasive are the products you listed vs. Meguiar's Dual Action Cleaner Polish (ie, DACP)? One of the things that irritates me about all the different products out there is that it's very hard to compare apples to apples because not all manufacturers rank their abrasiveness. Link to comment Share on other sites More sharing options...
StupidDent Posted March 17, 2009 Share Posted March 17, 2009 very cool applicator guide... http://www.lakecountrymfg.com/2006ApplicationGuide.jpg Link to comment Share on other sites More sharing options...
coredump4 Posted March 19, 2009 Author Share Posted March 19, 2009 Excellent chart! Link to comment Share on other sites More sharing options...
