Pumped Posted March 14, 2009 Share Posted March 14, 2009 so what could this be coming from? the only thing i can think of would be the driveshafts ..... i did not get under the car yet, just thought i should post something first to get some opinions form more experienced GT owners .... thanks guys Link to comment Share on other sites More sharing options...
Pumped Posted March 14, 2009 Author Share Posted March 14, 2009 i am almost positive this is the seal i need.. http://www.legacygt.com/forums/showthread.php?t=92936&highlight=Transmission+Fluid+leak Link to comment Share on other sites More sharing options...
987687 Posted March 14, 2009 Share Posted March 14, 2009 So did you pull the tranny or the engine? You are probably right though about that link. Mine leaks too... but it is between the middle and back section of my tranny... Link to comment Share on other sites More sharing options...
AWDxBOOST Posted March 14, 2009 Share Posted March 14, 2009 prolly the axle seal...you pretty much need to replace them whenever you take out the axles unless you are sweet enough to take it out without damaging it Link to comment Share on other sites More sharing options...
Pumped Posted March 15, 2009 Author Share Posted March 15, 2009 i pulled the tranny down Link to comment Share on other sites More sharing options...
Pumped Posted March 15, 2009 Author Share Posted March 15, 2009 So did you pull the tranny or the engine? You are probably right though about that link. Mine leaks too... but it is between the middle and back section of my tranny... you mean where the drive shaft get put in? Link to comment Share on other sites More sharing options...
987687 Posted March 15, 2009 Share Posted March 15, 2009 I think it is between the gearbox and center diff. Link to comment Share on other sites More sharing options...
blackfang Posted March 15, 2009 Share Posted March 15, 2009 Most likely you nicked the seal when putting the axles back in. You can replace them when you change the clutch if you like, but it can be done without damaging the seals. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
987687 Posted March 15, 2009 Share Posted March 15, 2009 Just get under there an clean it up really well so you can see where the oil is coming from. Link to comment Share on other sites More sharing options...
