tsunami Posted June 3, 2010 Share Posted June 3, 2010 +1 Link to comment Share on other sites More sharing options...
sumfoo1 Posted October 27, 2010 Share Posted October 27, 2010 What color are stock injectors? I bought an 05 with a vf52 allready on it but no up pipe down pipe etc and I'm kinda wondering if any other random parts were changed? Or if it was stage 2.5 ish and he put it back to stock as much as possible. Link to comment Share on other sites More sharing options...
-The Boss- Posted October 27, 2010 Share Posted October 27, 2010 What color are stock injectors? I bought an 05 with a vf52 allready on it but no up pipe down pipe etc and I'm kinda wondering if any other random parts were changed? Or if it was stage 2.5 ish and he put it back to stock as much as possible. Stock are yellow...modified are yellow. Pull one and take a pic for us Link to comment Share on other sites More sharing options...
mustangendsley Posted October 27, 2010 Share Posted October 27, 2010 We never had to take the fuel rails off at all on my 05 gt side feeds. This job took about 1 hr, not that bad. driver side was much easyer than the passenger side. Link to comment Share on other sites More sharing options...
SpeedNeeder Posted June 13, 2011 Share Posted June 13, 2011 I would like to see some instructions on this as well. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
smarty Posted October 13, 2011 Share Posted October 13, 2011 Does anyone know the thead/size of the screw that holds the injector hat down? Small Torx screw, one for each injector. Thanks Link to comment Share on other sites More sharing options...
subi_snipe223 Posted April 24, 2012 Share Posted April 24, 2012 Does anyone know the thead/size of the screw that holds the injector hat down? Small Torx screw, one for each injector. Thanks A little late, but i used a T25. Link to comment Share on other sites More sharing options...
DRsnoopy Posted September 13, 2012 Share Posted September 13, 2012 same here. No way I was putting that thing back in! I absolutely had to lift my manifold slightly to get the fuel rail out of the way.. I think that is why I had to lift it. I also had to relocate a ground connection on the driver's side since I did not put that plate back on. Its been a while, I somewhat forget. where did you relocate the ground too? Link to comment Share on other sites More sharing options...
meadr86 Posted January 31, 2013 Share Posted January 31, 2013 about this ground where did you guys re-locate it to? Link to comment Share on other sites More sharing options...
SBT Posted September 19, 2013 Share Posted September 19, 2013 It's only a safety point, but that "bracket" is there to protect the injectors from exposure during a collision, where anything intruding into the injector area could dislodge the fuel rail, allowing pressurized fuel to spray around the engine bay and cause a serious fire. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SPeC.B_MaZTer Posted May 11, 2015 Share Posted May 11, 2015 bump. are their any current removal install threads for the top feed injectors. I'm in the middle of this project and I'm having trouble getting these brackets removed.. Link to comment Share on other sites More sharing options...
SPeC.B_MaZTer Posted May 20, 2015 Share Posted May 20, 2015 okay I gess Bump again, I have my intake manifold released and the fuel line disconnect tool ready to use in the morning before I begin removing my stock STi/Spec.B fuel injectors. In the morning I will be removing the injectors and installing some GrimmSpeed phenolic spacers while the IM is loose, and also a set of new NGK 2309 spark plugs. The Deatschwerks 850cc topfeed injectors will arrive the next day so I SHOULD be ready for an easy install as long as nothing goes wrong tomorrow morning. I will post here with results since I cannot find any other current/reasonable thread regarding injector installation on a 2008 model. 5/19/2k15 Link to comment Share on other sites More sharing options...
rhino6303 Posted May 20, 2015 Share Posted May 20, 2015 It's pretty much identical to this. Link to comment Share on other sites More sharing options...
