rao Posted March 13, 2009 Share Posted March 13, 2009 I figured that the active cleansing agents would be a good idea. I know it is rated SM which is higher than Subaru requires and it is the correct grade, but now I am not so sure. Is my engine doomed? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Paradiso Posted March 13, 2009 Share Posted March 13, 2009 Yes, I'm afraid your car is doomed. However, if you hurry, you might save it. I heard that if you rev the engine pretty high then stick the intake into a 25 lb bag of very fine sand it'll port and polish your engine. That should take care of any of the damage done by the oil. Good luck, let us know how it turns out. Link to comment Share on other sites More sharing options...
rice_rocket Posted March 13, 2009 Share Posted March 13, 2009 No.. go and change it back or flush it with your synthetic. It's just not good to go back and forth between types. Link to comment Share on other sites More sharing options...
ean611 Posted March 13, 2009 Share Posted March 13, 2009 yes, your car is doomed to have a low friction substance lubricate your cylinders and turbo. DOOMED I TELL YOU! /Anyone else want some popcorn for this? Link to comment Share on other sites More sharing options...
ShockerGT Posted March 13, 2009 Share Posted March 13, 2009 Screw buying oil, I just use my neighbors used oil, much cheaper! Link to comment Share on other sites More sharing options...
bradlgt21 Posted March 13, 2009 Share Posted March 13, 2009 Get that ish out of there. And I mean all of it. Drain all the oil out. Replace with water and dawn dishwashing soap. Run car until it gets hot and starts foaming. Add water restart drain. Repeat 3-4 times or until suds go away. Replace with the good stuff and you should be fine. Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted March 13, 2009 Share Posted March 13, 2009 Get it out before it blows up! Link to comment Share on other sites More sharing options...
JoeFromPA Posted March 13, 2009 Share Posted March 13, 2009 http://www.pennzoil.com/products/motor_oil/images/mulit_grade.jpgIf you used pennzoil yellow bottle, you are safe. It's secretly synthetic. Link to comment Share on other sites More sharing options...
Beanboy Posted March 13, 2009 Share Posted March 13, 2009 No.. go and change it back or flush it with your synthetic. It's just not good to go back and forth between types. I hope my sarcasm meter isn't broken... I paused on this response! -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
imboden Posted March 13, 2009 Share Posted March 13, 2009 As long as you change your oil every day you will be fine. But I think you already do that. Link to comment Share on other sites More sharing options...
Bbc84 Posted March 13, 2009 Share Posted March 13, 2009 As long as you change your oil every day you will be fine. But I think you already do that. but dino oils break down faster than synthetic, so i think he needs to change his oil every hour. Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted March 13, 2009 Share Posted March 13, 2009 i read in one post he rebulids his motor everyday as well haha:lol: Link to comment Share on other sites More sharing options...
GTTuner Posted March 13, 2009 Share Posted March 13, 2009 Skip one quart and use Wesson, it smells like french fries. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 14, 2009 Share Posted March 14, 2009 Why would you ever switch from JDM Quaker State? Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted March 14, 2009 Share Posted March 14, 2009 Why not just run no oil? It will give you a good weight reduction I took off a whole second in the 1/4 mile with no oil! man I need extra butter for this thread! Link to comment Share on other sites More sharing options...
rao Posted March 14, 2009 Author Share Posted March 14, 2009 Why would you ever switch from JDM Quaker State? Well that's the problem my usual source dried up. I obviously do change the oil during my daily engine rebuild, but I suppose I will now have to change it every time a shut the car off Oh well, it's a small price to pay for piece of mind. The question is, what should my new oil of choice be? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted March 14, 2009 Share Posted March 14, 2009 http://upload.wikimedia.org/wikipedia/commons/1/16/Peanut_oil_bottle.jpg Link to comment Share on other sites More sharing options...
snow05gtRI Posted March 14, 2009 Share Posted March 14, 2009 The question is, what should my new oil of choice be? I say use a different oil every time you change it. Start with a brand and weight and keep switching brands until you've used a bunch of different ones. go in alphabetical order. switch weights starting with the lowest and increment up. go through brands again. repeat. Link to comment Share on other sites More sharing options...
franklin Posted March 14, 2009 Share Posted March 14, 2009 Non synthetic oil eats headgaskets Link to comment Share on other sites More sharing options...
StoplightAssassin Posted March 14, 2009 Share Posted March 14, 2009 I used hair gel one time b/c I was tired of getting oil on my hands when I do my oil changes. I just got a really big bottle for like 10 bucks! WOOT!! everywhere I went it smelled like a barber shop...ppl were all like WTF and I was like yeah bishes!!! I think next time I'm gonna try "I Can't Believe It's Not Butter!" Link to comment Share on other sites More sharing options...
fonts Posted March 14, 2009 Share Posted March 14, 2009 Short answer ..... yes. Your car is DOOMED. Link to comment Share on other sites More sharing options...
rexster Posted March 14, 2009 Share Posted March 14, 2009 The question is, what should my new oil of choice be? http://www.atr-lang.com/data/media/1/simpsons%20duff%20beer%20wallpaper.jpg Link to comment Share on other sites More sharing options...
AShoe Posted March 15, 2009 Share Posted March 15, 2009 just use the tears of newborn babies mixed with the captured souls of your ancestors. Doint this will not only prevent future engine damage. It will actually fix any damage those overpriced synthetic oils caused. Link to comment Share on other sites More sharing options...
EvilCamaroSS Posted March 15, 2009 Share Posted March 15, 2009 I have been running Maple Syrup for the last few hundred miles, I heard it lubricates a lot better, and also it smells awesome coming out of the tail pipes! Link to comment Share on other sites More sharing options...
legacy3076 Posted March 18, 2009 Share Posted March 18, 2009 Parraffin wax between machine surfaces is always good Link to comment Share on other sites More sharing options...
