terryg911 Posted March 4, 2009 Share Posted March 4, 2009 Hello, Juist purchased a 1993 Subaru that when Good and Warm (driven >15Miles) will grind 3rd gear on every shift. My guess change the fluid to a GOOD synthetic. Also the dif for the AWD. No turbo on this car Question: What fluid model type and weight do you all recomend for the 5 speed tranny? What fluid model type and weight do you all recomend for the Differential? In your experiance will this help the 3rd gear grind? Thanks Terryg Link to comment Share on other sites More sharing options...
