Paisan Posted March 3, 2009 Share Posted March 3, 2009 Has anyone thought of or actually done Brembos in the front and FHI 2-pot rears on the LGT. Downfalls? Etc. I'm open to ideas. I'm thinking the FHI rears may be a direct bolton due to the rear rotors being the same part # etc. I'm already aware of the proportioning valve issue, but other than that what pitfalls? -mike Link to comment Share on other sites More sharing options...
mwiener2 Posted March 3, 2009 Share Posted March 3, 2009 no increase in braking performance My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
jamal Posted March 3, 2009 Share Posted March 3, 2009 yep. and you need a bracket just like with brembos. Link to comment Share on other sites More sharing options...
Paisan Posted March 3, 2009 Author Share Posted March 3, 2009 Why do you need a bracket? I would guess because of the knuckle being different. As for "performance", I'm not looking for an upgrade in performace, I'm trying to find a way to prevent my rotors from cracking. Been cracking rotors like they are kids toys on my LGT and it's stock. Hawk HP+ pads, DBA 4000 Rotors.... -mike Link to comment Share on other sites More sharing options...
jamal Posted March 3, 2009 Share Posted March 3, 2009 fixed calipers bolt directly to the backing plate instead of using a caliper bracket. On top of that the bolt spacing for rear 2-pots is different (although brembos and 2-pots are interchangeable). To put 2-pots on a sliding caliper car you need these: Link to comment Share on other sites More sharing options...
mwiener2 Posted March 3, 2009 Share Posted March 3, 2009 runts included? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Paisan Posted March 3, 2009 Author Share Posted March 3, 2009 Yeah I've done the intall lots of times, just not a whole lot on the LGT, was thinking perhaps because we use the same rear rotor as the FHI 2-pot rears it might be a bolt-on. Now here is a followup question. FHI 2-pot rears or Brembo 2-pot rears. Advantage of the FHI ones is that there is less unsprung weight due to significantly ligher rear rotors than the STi rear rotors with the pressed in ring for the parking brake. mike Link to comment Share on other sites More sharing options...
