big lou Posted March 4, 2009 Share Posted March 4, 2009 Oops, forgot it was a wagon. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted March 4, 2009 Share Posted March 4, 2009 Oops, forgot it was a wagon. Not meaning to harp on you, but others might read this thread. It will not 100% work on every car, it depends on the tire. I can almost gaurantee that a tire that is about 8 or 9 mm wider (per side) will rub on my car. Going from a 235 width in a normal tire to a 245 width in a "wide" tire will be at least that much wider per side. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
devobuzz Posted March 4, 2009 Share Posted March 4, 2009 Also depends on how low and stiff your rear springs are. I'm running 235/40/17 Azenis with no rub on iON springs. Link to comment Share on other sites More sharing options...
caramall2 Posted March 14, 2009 Author Share Posted March 14, 2009 Well, I went the 235/40/17 route (have 17x8 rims) with the Star Specs. They just came in. The contact width (at the tread) is about 9"...about 1" more than my Nitto NT01 R-compounds (225/45 on 7.5 rims). I think my street set up may be better than my track set up ;-) I'm definitely planning to do a few laps on the Dunlops in addition to the Nittos (I've tracked the Nittos before already). I really think with coilovers, swaybars, the right alignment, etc., our cars can really use a 235 or 245. Link to comment Share on other sites More sharing options...
devobuzz Posted March 14, 2009 Share Posted March 14, 2009 So any rub? Link to comment Share on other sites More sharing options...
caramall2 Posted March 14, 2009 Author Share Posted March 14, 2009 I won't have them on until later this spring so I'll see then. Will try and remember to let you know. I thinkI'm going to roll the fender lips just in case. Link to comment Share on other sites More sharing options...
devobuzz Posted March 14, 2009 Share Posted March 14, 2009 Ah yes - you're in Canada. I bet you're itchin' to get them on! Link to comment Share on other sites More sharing options...
lawl Posted March 14, 2009 Share Posted March 14, 2009 Well, I went the 235/40/17 route (have 17x8 rims) with the Star Specs. They just came in. The contact width (at the tread) is about 9"...about 1" more than my Nitto NT01 R-compounds (225/45 on 7.5 rims). I think my street set up may be better than my track set up ;-) I'm definitely planning to do a few laps on the Dunlops in addition to the Nittos (I've tracked the Nittos before already). I really think with coilovers, swaybars, the right alignment, etc., our cars can really use a 235 or 245. They should fit fine. I have the same size re01r and no rubbing no matter what I do. car for sale. PM me! Link to comment Share on other sites More sharing options...
btlegacy Posted March 19, 2009 Share Posted March 19, 2009 I am thinking of purchasing the 245/45R17 or 245/40R17 RE-01R's on clearance at tirerack. What kind of wheels with what kind offset would you recommend for a stock 05 Sedan with stock suspension so that there are no rubbing issues? 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
caramall2 Posted March 19, 2009 Author Share Posted March 19, 2009 First, see Xenonk's sticky on tires and rims (go to wheels/tires, then look for his sticky). Second, I'm no expert but I've read lots of threads and have asked lots of people questions. The general feel I get is: 245/40/17 are a real tight fit from what I read. You need a fairly wide wheel too for that wide of a tire. You may get by with a 8" wheel, but probalby 8.5 would be better, 9 good too. I think +48 would be good, but you can check Xenonk's thread. Depending on tire brand, width can vary a lot (to give you and example, Dunlop Z1s 235/40/17 are 9" wide at the tread/contact surface, and 9.6 at the widest point further up the sidewall). I chickened out over concerns of rubbing and went with 235/40/17, but if you roll your fender lips and have the right offset, then you may get by without rubbing but I'm not sure on that. You're higher than me being on stock suspension, but there's also the concern of rubbing on the suspension itself. A few guys have told me the tire would be too big, a few have said it would be ok and they're running them. 245/45/17: You would not want to go that large of a diamter…way bigger diameter than stock (and the 245/40/17 is already bigger diameter than stock). Link to comment Share on other sites More sharing options...
boostsr20 Posted April 1, 2009 Share Posted April 1, 2009 245/40 on a 17x8 fit perfect on my car. I had to pull the rear rubber trim piece on the fender to give the extra couple mm of clearance but I have no issues. Lowered on Bilsteins/H techs. Link to comment Share on other sites More sharing options...
Guest Posted April 1, 2009 Share Posted April 1, 2009 245/40 on a 17x8 fit perfect on my car. I had to pull the rear rubber trim piece on the fender to give the extra couple mm of clearance but I have no issues. Lowered on Bilsteins/H techs. What offset, what tire? Link to comment Share on other sites More sharing options...
djsnoops Posted April 3, 2009 Share Posted April 3, 2009 i just got my G-Forces 17x8s today with star spec z1s. the tires are 235/40/17. i'm sure i should have no issues im on complete stock suspension right now. ill let you guys know how it fits hopefully by this weekend. im getting too anxious to put em on..but forecast shows snow on sunday/monday. Link to comment Share on other sites More sharing options...
boostsr20 Posted April 5, 2009 Share Posted April 5, 2009 What offset, what tire? et46 on Kumho SPT's. I also had the spt's in 225/40/18 and the sidewall felt soft, but they are great in this size. Very happy with the grip for the price. Link to comment Share on other sites More sharing options...
