cliffyourledshop Posted March 2, 2009 Share Posted March 2, 2009 http://img.photobucket.com/albums/v130/S14Swap240sx/cliffs%20leds/IMG_4099.jpg We decided to demo our new FlexiStrip Led’s on a 2006 Subaru Impreza. Our goal was to mimic the Audi style headlights, with out extensive modifications. In other words we did not want to make any modification that would not be easily removable. So these are the steps we took. Step 1: We began with the 48cm LED FlexiStrip, and laid it over the headlight to see where we would need to cut the LED FlexiStrip, to best fit the headlights. http://img.photobucket.com/albums/v130/S14Swap240sx/cliffs%20leds/IMG_1496.jpg When cutting the LED FlexiStrip it is important to remember that you have to cut the LED’s in groups of 3, but watch out for the power wires, pictures below, you can NOT cut them. So we would recommend exercising caution when cutting the LED FlexiStrip http://img.photobucket.com/albums/v130/S14Swap240sx/cliffs%20leds/IMG_4115.jpg Also note, after cutting the LED FlexiStrip hot glue needs to be applied to the cut to prevent water from damaging the internal wiring of the LED FlexiStrip. Other sealants such as silicone can be used. http://img.photobucket.com/albums/v130/S14Swap240sx/cliffs%20leds/IMG_4122.jpg Step 2: Now that we have the LED FlexiStrip cut to the size we wanted, it is necessary in our case to apply double-sided tape to keep the LED FlexiStrip in place. Depending on the application, we would also recommend using ZipTies as a form of mounting the LED FlexiStrip. Make sure you test fit the LED FlexiStrip before taping anything down! We adjusted the LED FlexiStrip with the hood closed, to make sure the install looked as clean and unnoticeable as possible. http://img.photobucket.com/albums/v130/S14Swap240sx/cliffs%20leds/IMG_1502.jpg http://img.photobucket.com/albums/v130/S14Swap240sx/cliffs%20leds/IMG_1505.jpg Step 3: In our application, we decided to replace the parking light bulbs with these new LED FlexiStrips. It is possible to retain both the LED FlexiStrip, and OEM Parking Light Bulbs but we decided not to. As far as powering the LED FlexiStrip, all that is needed is a 12v Source. So the power wires where spliced directly into the Parking Light Harness. Note: Make sure you double-check the polarity so you don’t have to redo the splice! http://img.photobucket.com/albums/v130/S14Swap240sx/06%20STI/IMG_1443.jpg http://img.photobucket.com/albums/v130/S14Swap240sx/06%20STI/IMG_1446.jpg Step 4: Make sure electrical tape is used to cover any wires you may have spliced, and everything is tucked away neatly! Take some pictures and show us what creative places you have used your YourLEDShop LED FlexiStrip!! Thanks to s14swap240sx for doing this writeup for us! Link to comment Share on other sites More sharing options...
PeterJMC Posted March 2, 2009 Share Posted March 2, 2009 Where do you purchase these and how much? Thanks Link to comment Share on other sites More sharing options...
sleeper8406 Posted March 2, 2009 Share Posted March 2, 2009 I'd like to see this done on a LGT...I'm curious to see how long those led strips last. Link to comment Share on other sites More sharing options...
cliffyourledshop Posted March 2, 2009 Author Share Posted March 2, 2009 Where do you purchase these and how much? Thanks You will see our thread under the vendor section, it has to be verified by a moderator first, possibly tomorrow itll be up -Cliff Link to comment Share on other sites More sharing options...
PeterJMC Posted March 2, 2009 Share Posted March 2, 2009 Loook at Mr_Luvs setup. I saw those in person and they look awesome. http://i6.photobucket.com/albums/y209/mrluv1/DSC00861.jpg Link to comment Share on other sites More sharing options...
sleeper8406 Posted March 2, 2009 Share Posted March 2, 2009 ^^^ Pics on car? Link to comment Share on other sites More sharing options...
PeterJMC Posted March 2, 2009 Share Posted March 2, 2009 None yet. but it shows it's possibilities Link to comment Share on other sites More sharing options...
djsnoops Posted March 2, 2009 Share Posted March 2, 2009 thats beautiful. Link to comment Share on other sites More sharing options...
cliffyourledshop Posted March 3, 2009 Author Share Posted March 3, 2009 they are now for sale under the vendor forum -Cliff Link to comment Share on other sites More sharing options...
sleeper8406 Posted March 3, 2009 Share Posted March 3, 2009 Where? Link? Link to comment Share on other sites More sharing options...
nemo Posted March 3, 2009 Share Posted March 3, 2009 http://legacygt.com/forums/showthread.php?t=107062 If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
cliffyourledshop Posted March 3, 2009 Author Share Posted March 3, 2009 thanks nemo! Link to comment Share on other sites More sharing options...
suzysube Posted March 7, 2009 Share Posted March 7, 2009 Finally got around to doing this. I also put back in my ddm kit. In the process of that, I broke the tab that swings over and holds the headlight bulb down. Anyone know of a DIY fix on that??? Or am I screwed and need to buy a new housing?? anyways, on to the pics. I think i need to do a little adjusting on it to get it look better. http://i70.photobucket.com/albums/i120/suzysube/P1010206.jpg http://i70.photobucket.com/albums/i120/suzysube/P1010207.jpg http://i70.photobucket.com/albums/i120/suzysube/P1010208.jpg Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted March 8, 2009 Share Posted March 8, 2009 Has anyone been able to fit the strip under the headlight (outside) but still have it be clearly visible? I'm worried that the spacing between the headlight and the bumper doesn't have enough clearance for that... and if my DDE's didn't short out from a faulty connector, I would have a setup just like Mr. Luv's :( But yea, I'm not sure I wanna go through the trouble of ovening my headlights again for that strip... Link to comment Share on other sites More sharing options...
suzysube Posted March 8, 2009 Share Posted March 8, 2009 http://i70.photobucket.com/albums/i120/suzysube/413.jpg http://i70.photobucket.com/albums/i120/suzysube/412.jpg http://i70.photobucket.com/albums/i120/suzysube/411.jpg http://i70.photobucket.com/albums/i120/suzysube/410.jpg Link to comment Share on other sites More sharing options...
cliffyourledshop Posted March 8, 2009 Author Share Posted March 8, 2009 wow, looks really good!!! looks better than the sti haha Link to comment Share on other sites More sharing options...
suzysube Posted March 8, 2009 Share Posted March 8, 2009 I really like it. Wish the parking light wires were not tucked and hidden away. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted March 8, 2009 Share Posted March 8, 2009 Pics of it wired up please! Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted March 8, 2009 Share Posted March 8, 2009 and how it is mounted please! Link to comment Share on other sites More sharing options...
suzysube Posted March 8, 2009 Share Posted March 8, 2009 Power i tapped into the white wire on the harness, for ground, black. They work with the low beams. When you turn on your high beams, they go off. If you want them on all the time, wire into the red. They will stay on with the high beams. We tapped into the wires on the headlight side of the harness. Hope this helps. Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted March 9, 2009 Share Posted March 9, 2009 Thanks a lot suzysube!! Are those colors the same for passenger and driver's side? Btw, where did you get the badge on your grille? Power i tapped into the white wire on the harness, for ground, black. They work with the low beams. When you turn on your high beams, they go off. If you want them on all the time, wire into the red. They will stay on with the high beams. We tapped into the wires on the headlight side of the harness. Hope this helps. Link to comment Share on other sites More sharing options...
suzysube Posted March 9, 2009 Share Posted March 9, 2009 Yes they are the same color on both sides. The badge is the stock badge from the rear of the car. when I debadged, i took the emblem, put some double sidded sticky on there, and just attached it. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted March 9, 2009 Share Posted March 9, 2009 How did you wire together? Link to comment Share on other sites More sharing options...
suzysube Posted March 10, 2009 Share Posted March 10, 2009 we cut and soldered the wires together. Link to comment Share on other sites More sharing options...
itsme Posted March 10, 2009 Share Posted March 10, 2009 http://legacygt.com/forums/showthread.php?t=107062 Nemo is a very sweet and helpful. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
