levis76 Posted January 27, 2009 Share Posted January 27, 2009 I have a 98 LGT. I will be replacing the brake master cylinder, fluid, pads, and turning the rotors just to clean them up. I noticed my remanufactured MC did not come with the reservoir or a bench bleed kit. A few questions, how difficult is it to swap the reservoir without causing damage, how am I going bleed the MC properly, and finally, how much fluid will I need to fill and bleed the system? The only spec I can find is the reservoir capacity, but nothing on total system capacity. Link to comment Share on other sites More sharing options...
