Tzarof smurfs Posted January 31, 2009 Share Posted January 31, 2009 (Had my switch replaced under warrenty a year or so ago.) +1 Link to comment Share on other sites More sharing options...
jeepthrills Posted January 31, 2009 Share Posted January 31, 2009 having been in 2 different 05 LGT's in the last month...they both were sticky...and felt like they were gonna break. Link to comment Share on other sites More sharing options...
Dusty B Posted January 31, 2009 Share Posted January 31, 2009 I've had the same condition since purchasing my 05 lgt. Never lean my leg against the door so no pressure. You'll learn to live with it once you find the sweet spot. Link to comment Share on other sites More sharing options...
Scotty Posted January 31, 2009 Share Posted January 31, 2009 My driver switch will stick when you push it down. Sometimes it would stop working altogether. Since then I have found if you pull up first, it won't stick when pushing down. The new Impreza has a small hook in the frame on the gas cap door to hold the wire. Link to comment Share on other sites More sharing options...
mightyS Posted January 31, 2009 Share Posted January 31, 2009 My drivers window switch was fine for the first year and then started sticking. Now after 4 years, it still works, but I have to smash it down every time. All the other buttons/switches work fine. Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted February 1, 2009 Share Posted February 1, 2009 Just another "what makes a Subaru a Subaru"... Link to comment Share on other sites More sharing options...
TPLGT Posted June 10, 2009 Share Posted June 10, 2009 In for the sticky/clunky switch problem. Kind of a pia! Rehab is for quitters. Link to comment Share on other sites More sharing options...
waynekranzler Posted June 10, 2009 Share Posted June 10, 2009 After reading all the sticky driver window switch posts over the years and when mine started sticking, I had it replaced under warranty before it expired. Link to comment Share on other sites More sharing options...
94sportsedan Posted June 10, 2009 Share Posted June 10, 2009 Mine sticks enough to give you express up feature, just have to remember to tip it back to neutral position though. Link to comment Share on other sites More sharing options...
snow05gtRI Posted June 10, 2009 Share Posted June 10, 2009 i've had it get stuck and i do not notice it right away and i'll come back to it and un-stick, and then the window wont work for some amount of time. so far it has come back but i usually just keep trying up/down until it goes again. it seems to always happen when approaching a toll booth haha Link to comment Share on other sites More sharing options...
IanB Posted July 21, 2009 Share Posted July 21, 2009 Glad to see I'm not the only one with this issue, really the only thing I have found wrong with the car so far (other than being really slow in 1st gear, lol). Link to comment Share on other sites More sharing options...
f1anatic Posted July 21, 2009 Share Posted July 21, 2009 I replaced it under warranty about 1 year ago Link to comment Share on other sites More sharing options...
SubOperator Posted July 21, 2009 Share Posted July 21, 2009 mine started to get stuck also about a year ago. So I used some silicon spray and it worked like new if not better. I simply do it now every spring when cleaning door seals, etc. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
TPLGT Posted July 21, 2009 Share Posted July 21, 2009 Hmmm silcon...good idea! Rehab is for quitters. Link to comment Share on other sites More sharing options...
IanB Posted July 28, 2009 Share Posted July 28, 2009 I tried the silicon spray last night, didn't help much if at all. You guys are spraying through the gap to get it under the rocker switch correct? How much did you use? I didn't want to flood it with the stuff. Link to comment Share on other sites More sharing options...
SpawnGT Posted July 28, 2009 Share Posted July 28, 2009 UPDATE: i had mine replaced three times in my 05 LGT. i know the reason for it sticking according to the subaru. When it rains or drizzles and your window is open the natural curvature of the door allow for water to get into the switch, and the switch is actully slightly rusted. Ive seen it on two of the three that there was rust under the switch causing failure. Link to comment Share on other sites More sharing options...
iyalla Posted July 28, 2009 Share Posted July 28, 2009 ^^Wow. I guess they assumed we would never open our doors in the rain ....ooohh Subaru:rolleyes: Link to comment Share on other sites More sharing options...
pierce88 Posted July 28, 2009 Share Posted July 28, 2009 Have the same problem... Burnt through one window motor... Looking for solutions to make it less sticky besides the obvious one of self control -Pierce Link to comment Share on other sites More sharing options...
TPLGT Posted July 29, 2009 Share Posted July 29, 2009 Anyone know if just the switch can be replaced? Someone had posted in another thread that the whole 5 swtiches and housing needs to be replaced as 1 unit. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Siper2 Posted July 29, 2009 Share Posted July 29, 2009 This is another example of a "Hey, I'm not the only one!!" thread. Same here, with my '05. Tricky driver window switch, the rest are fine. Link to comment Share on other sites More sharing options...
jagcars26 Posted July 29, 2009 Share Posted July 29, 2009 Same deal with my 05 GT wagon. Link to comment Share on other sites More sharing options...
HipsterDoofus Posted July 29, 2009 Share Posted July 29, 2009 This happened to me. I ended up changing my hamster wheel and everything was golden. Hope this helps! Link to comment Share on other sites More sharing options...
Gmoe Posted July 29, 2009 Share Posted July 29, 2009 ++ My driver window switch feels like it came straight out of a Lego kit. Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted July 30, 2009 Share Posted July 30, 2009 ++ My driver window switch feels like it came straight out of a Lego kit. +1...lol Link to comment Share on other sites More sharing options...
Ssej Posted July 30, 2009 Share Posted July 30, 2009 Yup my switch is the same, even getting worse. You'd think on these 120 degree days in Phoenix it would loosen up the plastic a bit... but no... Link to comment Share on other sites More sharing options...
