usawinston Posted January 26, 2009 Posted January 26, 2009 Hey guys, I just purchased a pre owned 09 Spec B with 3k miles. I love this beast, but I've noticed something unusual when I shift up into 4th gear at high RPM's: the shifter (not the clutch) makes a rubbing noise, almost like a clicking. You can feel it in your hand because it's a rapid vibration. Any clues? Thanks.
joeaux Posted January 26, 2009 Posted January 26, 2009 Don't know. My '08 doesn't do it. I'd take it back to the dealer. Give them a chance to see what it is. If they blow you off, well, you've still got the rest of the warranty to get it fixed. -joe-
RockyMtnGT Posted January 26, 2009 Posted January 26, 2009 Is there a short shifter installed? When I installed my Kartboy shifter it definitely made more noise/vibration in this area -particularly around 3k rpm. Compare your stick height and throws to a new non-short shift car on the lot to be sure. At any rate I'd get it checked.
987687 Posted January 26, 2009 Posted January 26, 2009 It doesn't happen on my 13 year-old car. Get it checked out.
SCSpecB Posted January 26, 2009 Posted January 26, 2009 Haven't noticed it in my '08 either....It should have an STI short shifter installed as standard equip. I agree as well with the above to get it checked out.
RJS5689 Posted January 26, 2009 Posted January 26, 2009 Haven't noticed it in my '08 either....It should have an STI short shifter installed as standard equip. I agree as well with the above to get it checked out. No, a short shifter is an option on our cars. To the OP, get it looked at. My 2008 doesn't do that.
ordiga Posted January 26, 2009 Posted January 26, 2009 No, a short shifter is an option on our cars. To the OP, get it looked at. My 2008 doesn't do that. Yes, the STi short shifter was an option on my specB....not standard equipment...
BoozeRS05 Posted January 26, 2009 Posted January 26, 2009 I think he meant it should be the standard, not an option.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving
Sunra Posted January 27, 2009 Posted January 27, 2009 I have a brand new '09 and haven't noticed that issue...
SCSpecB Posted January 27, 2009 Posted January 27, 2009 No, a short shifter is an option on our cars. I stand corrected, I found my window sticker and it seems I got to pay for it ...and yes it SHOULD be the standard hahha
usawinston Posted January 27, 2009 Author Posted January 27, 2009 Thanks for your help. I'm going to get it checked out. Any ideas what the mechanical issue may be?
tealdub Posted January 27, 2009 Posted January 27, 2009 Should be called MY09 Subaru Legacy specB(roken).
fonts Posted January 28, 2009 Posted January 28, 2009 I haven't experienced that with my 07 .... either stock or after I got the Kartboy STS.
Ricardo Posted April 14, 2009 Posted April 14, 2009 I have the same issue on an 08 spec B. Cannot find the source of the problem... Have you found yours ? Thanks !
RedAce Posted April 15, 2009 Posted April 15, 2009 Possibly your synchros? You said pre-owned? Maby the person who owned it before you didn't know how to drive a stick and rocked the s**t out of the transmission...
mikeislord Posted April 15, 2009 Posted April 15, 2009 RedAce is right. Could be synchros. That car is too new to have a shifting issue. Take it in and demand warranty work to get it to what you'd expect from a car with 3k miles. As long as you keep taking it in, they have to document every time you come in.
