19 inch wheels & rubber rule!!
pachilla
I have seen my car before. But, if you really want to see it again here it goes.:)
http://i167.photobucket.com/albums/u156/itsmebryan/124714.jpg
http://i167.photobucket.com/albums/u156/itsmebryan/112332.jpg
http://i167.photobucket.com/albums/u156/itsmebryan/112326.jpg
http://i167.photobucket.com/albums/u156/itsmebryan/172407.jpg
This with KW V.2 set at 1/4" below max height. My 19x7.5 w/ 225/35/19 don't rub. The wheels just tuck under the fenders.
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
Just found out that my tire is rubbing (or touching) slightly against the plastic wheel well liner (area behind the foglamps)at stock height.
I guess +40mm offset wheels swing the front tires further forward when making tight turns.
Looks good.
I like it stock and with a drop. You can't loose.
What color code is that? I suspect it's not available USDM.
Hi, the color code is 45A "Urban Grey Metallic" and it is available in the US (but maybe not USDM Outback) since I bought a Subaru touch up paint color code 45A from the US.
Dropping it means I must give up on the the stock self-leveling rear strut so I am still trying to decide.:cool:
  • 4 months later...
  • 1 month later...
beautiful OB, where does everyone get the sti genome mufflers from?????? i want em sooo bad
I bought them used in Japan. The build quality is amazing.
be aware that there are at least 8 different versions of it.
Sedan versions have shorter tips (2 inches) and I have sedan version on my outback.
SG417AG010 Wagon, Turbo and 3.0R
SG417AG010 Wagon with Turbo
SG417AG030 (Wagon for2.0L NA 4 cylinder engine
SG417AG033 (Wagon with 2.5L & 3.0L NA engine
SG417AG000 B4 Sedan, Turbo and 3.0R engine
SG417AG003 B4 Sedan, Turbo and 3.0R engine
SG417AG020 B4 Sedan with 2.0L NA 4 cylinder engine
SG417AG023 (B4 Sedan with 2.5L & 3.0L NA engine
my other post about the STi Genome
http://legacygt.com/forums/showthread.php?t=87923&highlight=gemone
  • 7 months later...
