FASTONE Posted December 22, 2008 Share Posted December 22, 2008 Hello, i have finally got a Stage 2 tune opensource, car feels much better now, i just want to make sure that everything is running ok, my freind did the tune, he did mostly wrx before, so also attached logs and my map. So to all TOOONERS, please let me know if everything ok with the map. Thank you Map: http://www.fileshost.com/en/file/75843/stage-2-r5-hex.html Logs: http://www.fileshost.com/en/file/75844/romraiderlog-20081220-200136-csv.html http://www.fileshost.com/en/file/75847/romraiderlog-20081220-204918-csv.html Link to comment Share on other sites More sharing options...
FASTONE Posted December 22, 2008 Author Share Posted December 22, 2008 anyone?? Link to comment Share on other sites More sharing options...
Infamous1 Posted December 23, 2008 Share Posted December 23, 2008 You need a different host, I cannot download the file without first becoming a member. www.box.net Link to comment Share on other sites More sharing options...
enthusiast Posted December 23, 2008 Share Posted December 23, 2008 Enter the captcha letters submit then scroll to the bottom. You should see it counting down and then you can download. I was able to get the files. My mod list Link to comment Share on other sites More sharing options...
Infamous1 Posted December 23, 2008 Share Posted December 23, 2008 Yeah did that, it didn't work for me... Post a screen shot... Link to comment Share on other sites More sharing options...
testes1010 Posted December 23, 2008 Share Posted December 23, 2008 It looks ok. A bit conservative for a STG2 but safe. Link to comment Share on other sites More sharing options...
FASTONE Posted December 23, 2008 Author Share Posted December 23, 2008 Here is the on box.net for all those who could not get them. Map: http://www.box.net/shared/e9bx6volg2 Logs: http://www.box.net/shared/zeg4a44erh http://www.box.net/shared/kxobs8l9iy and also dou you know why the timing is off by about 3 degreees from the map continuously. also is it ok af far as AFT, i think i get worse gas milage, that could be that im WOT is ALOT, lol Thank you Link to comment Share on other sites More sharing options...
Infamous1 Posted December 23, 2008 Share Posted December 23, 2008 The car seems to be running ok, there is only one point in the logs where I identified knock. However the logs don't get a good diagnosis of the tune. You need to to a single gear pull in third from 2K rpms to redline. As for the LTFT's you need to post the AF learning for A, B, C and D ranges. But from the logs I can pretty much tell your fueling is off target by quite a bit(lean), also you aren't coming close to your boost targets as well. Link to comment Share on other sites More sharing options...
FASTONE Posted December 23, 2008 Author Share Posted December 23, 2008 Pmed Link to comment Share on other sites More sharing options...
FASTONE Posted December 24, 2008 Author Share Posted December 24, 2008 can someone else say whether i need to retune or am i ok like this Link to comment Share on other sites More sharing options...
enthusiast Posted December 24, 2008 Share Posted December 24, 2008 I think infamous told you what to do and what was wrong with your tune. You need to log in 3rd gear from ~2K RPMs WOT to redline. Keep in mind it is Christmas Eve for most people on this forum too. My mod list Link to comment Share on other sites More sharing options...
Airboy Posted December 25, 2008 Share Posted December 25, 2008 The two logs are not from the same map, are they? Looks like the file with the later timestamp is the one that goes with the attached ROM file (uses lower timing) Link to comment Share on other sites More sharing options...
3gsucks Posted December 25, 2008 Share Posted December 25, 2008 the tune was done by me. No the logs are not all from the same map and i dont even know if the logs from the final map were posted. The tune was ok in third but after we tested it in forth we got some timing pulled. I went back and gave fuel on topend and reduced timing because over 5200 the car would pull timing in forth gear. this is why the afr and timing are not matching the map. the mapped afrs and timing matched the final map on the last map we logged in forth and no timing was pulled. considering he wanted no governer I then decide it was best to keep it on the conservative. thanx nick Link to comment Share on other sites More sharing options...
FASTONE Posted December 26, 2008 Author Share Posted December 26, 2008 hi, Nick, i have to tell you, thank you. Car pulls nice and i just ordered a cable, so i can data log, i will post logs as soon as i get the cabke. Link to comment Share on other sites More sharing options...
3gsucks Posted December 28, 2008 Share Posted December 28, 2008 like i said if you have any problems just give me a call. I remember you saying something about getting a cat-back the tune should still be good even with a cbe. btw you were asking about the grapher i was using. AirBoy is the Man he is the one that made that spread sheet to do that stuff. Link to comment Share on other sites More sharing options...
