jcSKYhigh Posted December 21, 2008 Share Posted December 21, 2008 Is there way i can switch between economy and stage2 without going through test mode? Or is there a way i can just plug it in on the fly and just switch between different maps? THANKS FOR YOUR TIME ON READING THIS THREAD! Link to comment Share on other sites More sharing options...
craig09GT Posted December 21, 2008 Share Posted December 21, 2008 yes, just flash stage 2 as your base map (through test mode) and then load the economy map as a realtime map as needed. You can switch realtime maps in 30 seconds without the test mode. It will stay in memory unless you disconnect the battery. Link to comment Share on other sites More sharing options...
jcSKYhigh Posted December 21, 2008 Author Share Posted December 21, 2008 Actually unhook the battery or just disconnect the AP? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted December 21, 2008 Share Posted December 21, 2008 Actually unhook the battery or just disconnect the AP? He's saying the real-time map will stay in memory unless the ECM loses power. Link to comment Share on other sites More sharing options...
LGT Dave Posted December 21, 2008 Share Posted December 21, 2008 A realtime map will stay on your ECU until the ECU is reset either using the "ECU Reset" function found on the AP itself or by unhooking the battery. You can disconnect the AP from the car and it will still stay there. Link to comment Share on other sites More sharing options...
jcSKYhigh Posted December 21, 2008 Author Share Posted December 21, 2008 THANK YOU! and MERRY CHRISTMAS Link to comment Share on other sites More sharing options...
jeepthrills Posted December 23, 2008 Share Posted December 23, 2008 just how much better does your MPG get with the economy map? Link to comment Share on other sites More sharing options...
lepich Posted December 29, 2008 Share Posted December 29, 2008 Forget economy, my friends.. Gas is 50% cheaper now. Run baby, run!! :-) There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
