BLKGT5 Posted December 19, 2008 Share Posted December 19, 2008 http://members.cox.net/thenamelessguild/Datalog.csv Here's my quick AP Stg2 Log. Everything look ok? Anyone have that HP calculator? K&N Panel Stg2 91oct Nvidia Catless down Modified Catback Now that I have alternative transportation I can try the up pipe install again, since it kept getting stuck. I've been holding off since I’ am hoping to get a bigger turbo. Link to comment Share on other sites More sharing options...
lepich Posted December 22, 2008 Share Posted December 22, 2008 You datalog wrong data.. Search and find (do not remember all) what to datalog. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted December 23, 2008 Share Posted December 23, 2008 Engine Speed (rpm) Engine Load (Direct)* (g/rev) FLCK FBCK Ignition Timing (degrees) Knock Correction (degrees) Manifold Rel. Pressure (Corrected) (psi) Mass Air Flow (g/s) Primary Wastegate Duty Cycle (%) Throttle Opening Angle (%) There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
BLKGT5 Posted December 24, 2008 Author Share Posted December 24, 2008 I do not see those features on the AP selections. I'm guessing I'll have to use a laptop and that street tuner software? I can't wait to put the up pipe on now and see if the mass air flow increases! I'm up to 240g/s now at 1400ft with crappy humid weather out atm. Link to comment Share on other sites More sharing options...
lepich Posted December 24, 2008 Share Posted December 24, 2008 I use roamraider logger and laptop There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
