Underdog Posted December 30, 2008 Share Posted December 30, 2008 Here's every tank's mileage that I have record of. The last 5 tanks are crazy because I just went on a 1,000 mile road-trip to Ontario, but over the last year (starting at ~27,000 miles) you can see my car has been averaging 24mpg, through 90 degree summers and sub-freezing winters. My 60 mile daily commute is a mix of ~75%hwy/25%city. Stock power, 93 octane. The Crimson Dynamo Link to comment Share on other sites More sharing options...
BoozeRS05 Posted December 30, 2008 Share Posted December 30, 2008 ^ wow, you're a freak.. Good stuff tho.. Then there is something wrong with mine, cause my studder is there randomly from idle to WOT under about 4k rpm. And its cured by disconnecting the battery, and is happy for a week or so. Check that the injectors are OK, and also that the O2 sensors are OK. If one injector is giving too much it may cause the ECU to mis-tune the others. I agree with this.. Check plugs & coil packs too, if you find any problems with the above & you get them fixed, I bet your mpg will increase significantly.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
schwartzki Posted December 31, 2008 Share Posted December 31, 2008 New plugs, dad (auto tech) said the coil packs were fine, agreed that i should try injector cleaner. On tomorrows todo Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted December 31, 2008 Share Posted December 31, 2008 Here's every tank's mileage that I have record of. The last 5 tanks are crazy because I just went on a 1,000 mile road-trip to Ontario, but over the last year (starting at ~27,000 miles) you can see my car has been averaging 24mpg, through 90 degree summers and sub-freezing winters. My 60 mile daily commute is a mix of ~75%hwy/25%city. Stock power, 93 octane. MMMMMM...data.....I love it. Or to put it another way "More input Stephanie!!!" Link to comment Share on other sites More sharing options...
Underdog Posted December 31, 2008 Share Posted December 31, 2008 Batteries Not Included? That chart is a mere slice of the excel spreadsheets I keep on the car. The Crimson Dynamo Link to comment Share on other sites More sharing options...
itsme Posted January 4, 2009 Share Posted January 4, 2009 I found I get the best mileage watching my boost gauge. If I keep the vacum at 10 or higher I get the best mpg. It's funny how a slight move of your foot can effect the mpg. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
schwartzki Posted January 7, 2009 Share Posted January 7, 2009 Car is a horrid gas hog...ill be bitching more when gas is back to 4/gal Link to comment Share on other sites More sharing options...
