jsimonetti Posted December 17, 2008 Share Posted December 17, 2008 I recently purchased http://legacygt.com/forums/attachment.php?attachmentid=52636&d=1210556343 However after talking to a lot of people, I realized that the work that would go into making that bad boy fit on my car would cost a lot more than finding an intake that fits on my car right. I was wondering if anyone knew of a solution that I could find, so that I could get an intake on my 2.5i. It is an 09 legacy 2.5i special, and I would *prefer* SPT parts but I dont really mind going with another company. I figure if I can get the intake situation tackled, Ill try my hand at the exhaust. Let me know if you guys got anything for me. Thanks! Link to comment Share on other sites More sharing options...
aigochamaloh Posted December 17, 2008 Share Posted December 17, 2008 Most cold intakes I've seen that go on a 2.5 N/A come with a long ass pipe that replaces all that tubing under the hood, including the big box right on top of the engine. I'm assuming that's for turbo cars. Link to comment Share on other sites More sharing options...
OhBe1 Posted December 17, 2008 Share Posted December 17, 2008 If it's for the turbo (I'm almost certain it is) - it won't fit without modification, and the sensor will not be measuring the actual airflow. You'll run lean, and that will be bad. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 17, 2008 Share Posted December 17, 2008 Our stock intake is sufficient enough. Unless you just want noise, keep the stock system but replace the filter with a high-flow aftermarket filter. Link to comment Share on other sites More sharing options...
jsimonetti Posted December 17, 2008 Author Share Posted December 17, 2008 Well Im doing it for 2 reasons really 1) The noise 2) The 'bling' effect. And considering Ill probably put an exhaust on, I think it would be nice to have the whole air flow system done. I know that piece is for the turbo, I was just wondering if anyone had any links to ones that I could pick up and install without any cutting *note, if I need to cut, I will, but It would be preferable not to Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted December 17, 2008 Share Posted December 17, 2008 If you just want noise... remove the intake silencer and cut/drill holes in your airbox. You can also just do the hogzaust mod for added noise in the exhaust. Total cost = $0.00 Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted December 17, 2008 Share Posted December 17, 2008 I know that piece is for the turbo, I was just wondering if anyone had any links to ones that I could pick up and install without any cutting *note, if I need to cut, I will, but It would be preferable not to http://legacygt.com/forums/showthread.php?t=58727 Small amount of customization needed. Read up and have fun! You should also check out the N/A forum on NASIOC. There is a nice write-up on the issues with air intakes(I believe its a sticky by williaty). Link to comment Share on other sites More sharing options...
firepyro515 Posted December 18, 2008 Share Posted December 18, 2008 find an intake that fits a 2.5 impreza from 98-01. They have the best fit! for just a quick fix, i would just get a K&N filter. Moving the MAF or swapping the air box will throw a code (at least thats what the majority of people have said) Link to comment Share on other sites More sharing options...
The Suby Posted January 8, 2009 Share Posted January 8, 2009 I have thrown a code even though I used MAF relocater. I am going to do the 2.5 Impreza from 98-01 intake Link to comment Share on other sites More sharing options...
apexjapan Posted January 9, 2009 Share Posted January 9, 2009 I've got a prototype sitting at the top of my to-do pile. It's actually been designed for the 08 Impreza 2.5i, but I'm wagering that, like turbo models, the setup is exactly the same. I'll be doing some fitting tomorrow on a Legacy to see. Cheers, Paul Hansen http://www.avoturboworld.com Link to comment Share on other sites More sharing options...
N.sane Posted January 9, 2009 Share Posted January 9, 2009 ^Yaaay! I love how AVO and Rallitek give the 2.5i guys some love Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted January 9, 2009 Share Posted January 9, 2009 Awesome. That will def. be on my to-do list after I replace the short block. Link to comment Share on other sites More sharing options...
OhBe1 Posted January 10, 2009 Share Posted January 10, 2009 Running lean will give you all the noise you want. For a while.... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
D_J Posted January 10, 2009 Share Posted January 10, 2009 I've got a prototype sitting at the top of my to-do pile. It's actually been designed for the 08 Impreza 2.5i, but I'm wagering that, like turbo models, the setup is exactly the same. I'll be doing some fitting tomorrow on a Legacy to see. Cheers, Paul Hansen http://www.avoturboworld.com Good deal...I am very happy with just your panel filter alone. Definitely interested in any other minor tweaks to improve performance. Link to comment Share on other sites More sharing options...
katalyst Posted January 10, 2009 Share Posted January 10, 2009 ^ +1 avo panel filter ftw !! Link to comment Share on other sites More sharing options...
smushybrain Posted January 21, 2009 Share Posted January 21, 2009 I have the AVO panel filter and love it as well. I would be interested in an aftermarket intake pipe that went from the stock air box to the throttle body, though! *hint* *hint* Link to comment Share on other sites More sharing options...
CCSubaru Posted January 22, 2009 Share Posted January 22, 2009 Does putting a high-flow filter really make the sound better? If so how much do they cost? Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted January 22, 2009 Share Posted January 22, 2009 Does putting a high-flow filter really make the sound better? If so how much do they cost? It does add a nice sucking noise to the air induction when getting on the gas, but its not ricer loud or anything. If you just want noise, do a CAI or something to that effect. Link to comment Share on other sites More sharing options...
CCSubaru Posted January 22, 2009 Share Posted January 22, 2009 well how much does just a filter cost approx? Link to comment Share on other sites More sharing options...
BCushidō Posted January 22, 2009 Share Posted January 22, 2009 K&N performance air flow for '08 Legacy, at autozone, is $48.99. Link to comment Share on other sites More sharing options...
CCSubaru Posted January 22, 2009 Share Posted January 22, 2009 thank you Cushido Link to comment Share on other sites More sharing options...
firepyro515 Posted January 22, 2009 Share Posted January 22, 2009 Yeah, mine was around $45, easy to install, just make sure that you clean it every couple months. Link to comment Share on other sites More sharing options...
Madjik_Man Posted January 22, 2009 Share Posted January 22, 2009 okay, dumb question here What does the K&N filter do to the 2.5i in terms of performance? Link to comment Share on other sites More sharing options...
D_J Posted January 22, 2009 Share Posted January 22, 2009 Slight improvement in acceleration...plus you can wash them every few months instead of having to buy another standard paper filter. I think the AVO is better quality than K & N for about the same price. Link to comment Share on other sites More sharing options...
Madjik_Man Posted January 23, 2009 Share Posted January 23, 2009 Slight improvement in acceleration...plus you can wash them every few months instead of having to buy another standard paper filter. I think the AVO is better quality than K & N for about the same price. cool, thanks Link to comment Share on other sites More sharing options...
