DarkLegacy Posted December 15, 2008 Share Posted December 15, 2008 Well... My inspection is up and and I need to have a new inspection done. The only problem is that one of my headlights blew... No big deal right... Well, I take the light bulb out and I see that the bulb has blown. The bulb has literally exploded. There are pieces of glass in the lens chamber. I replaced the bulb, but the light is very dim. I thought it was the bulb but I took the replacement bulb and used it on the other side. On the other side, the bulb works fine. I think there may be a short or something. Can someone help me out pleassseeee... I dont even know where to look. :confused::confused: Thanks guys Link to comment Share on other sites More sharing options...
PeterJMC Posted December 15, 2008 Share Posted December 15, 2008 I saw that happen once with my friends Cobra. He had to replace his entire housing because glass particles embedded themselves into the inside of the plastic housing. Not sure what caused it but I'm interested to find out what happened to yours! Link to comment Share on other sites More sharing options...
DarkLegacy Posted December 15, 2008 Author Share Posted December 15, 2008 well... we had a real bad rain storm here and i had to go through some bad puddles... and the next day the head light was out... anyone have any ideas of where i should be looking for a short or something like that? Link to comment Share on other sites More sharing options...
05gtlimited300 Posted December 15, 2008 Share Posted December 15, 2008 theres an increased resistance somewhere. check all the wiring and the connections themselves Link to comment Share on other sites More sharing options...
DarkLegacy Posted December 16, 2008 Author Share Posted December 16, 2008 what do you mean by increased resistance? I checked the wiring around the lens housing itself and I saw some exposed wire. I taped it up with electrical tape but it didnt solve the problem. Link to comment Share on other sites More sharing options...
05gtlimited300 Posted December 16, 2008 Share Posted December 16, 2008 resistence is just like a way to slow current. you headlights are a simple circuit. since there is still light output, then there is no sort or a break in the circuit but an increase in resistance therefor minimizing the light output. So somewhere (which will be hard to find) there is something causing an issue. check the headlights ground and connections to the actually bulb. also if you have a voltmeter, check to see if the bulb is getting all 12+volts Link to comment Share on other sites More sharing options...
axolotl81 Posted December 16, 2008 Share Posted December 16, 2008 Something similar to your problem happened to me with my fog light. I have an 08 specb and had some yellow bulbs in the fog lights. My passenger side bulb went out unnoticed. I discovered it when I saw what looked like a yellow puddle inside the housing. What happened was the bulb exploded and cracked the foglight lens. I guessed maybe because it was just a cheapy bulb. I haven't fixed the bulb yet (too lazy right now), but hopefully won't have a problem like a short or something. Link to comment Share on other sites More sharing options...
DarkLegacy Posted December 16, 2008 Author Share Posted December 16, 2008 Thank you for the input guys! Link to comment Share on other sites More sharing options...
DarkLegacy Posted December 23, 2008 Author Share Posted December 23, 2008 I am still not able to fix my headlight... It seems that the fog light on that side works, and when I turn on the brights the light goes out totally. Anyone have any ideas? Link to comment Share on other sites More sharing options...
underpowerd Posted December 23, 2008 Share Posted December 23, 2008 *double* Link to comment Share on other sites More sharing options...
underpowerd Posted December 23, 2008 Share Posted December 23, 2008 and when I turn on the brights the light goes out totally. Anyone have any ideas? ^ that part's ok, highbeams switch off the other lights. Link to comment Share on other sites More sharing options...
rice_rocket Posted December 23, 2008 Share Posted December 23, 2008 Use a volt meter and check your voltage going to the bulbs. If it's not the same on both sides you most likely have a melted wire in the harness somewhere. Either way that's not going to fail your inspection. Get it done and then go trace wires back until you can find the problem.. pain in the butt for the winter, but if it is shorted it might be heating up and melting other wires. Link to comment Share on other sites More sharing options...
DarkLegacy Posted December 24, 2008 Author Share Posted December 24, 2008 good advice guys... i will let you know what happens... i wish i was better with electicals. Link to comment Share on other sites More sharing options...
