Metal2You Posted December 13, 2008 Share Posted December 13, 2008 I finally got around to installing my Perrin TMIC and the timing was great because I received my updated Tuning Alliance stage II map. Then I data-logged it with the new firmware from Cobb. So, how does this log look? Is there anything missing that I should log for next time?datalog1.pdf Link to comment Share on other sites More sharing options...
Spec B Posted December 13, 2008 Share Posted December 13, 2008 Log only: Throttle opening angle Manifold relative pressure Primary Wastegate Duty Cycle Total Timing Knock Sum Mass air flow (not necessary, but nice to look at) What gives us the best insight into whether your tune is safe is for you to log 3rd gear from 2000 RPM to redline at full throttle. Good luck. Link to comment Share on other sites More sharing options...
Metal2You Posted December 13, 2008 Author Share Posted December 13, 2008 No need for AFR? With the AP2 firmware I can log Throttle Position Boost Wastegate Duty MAF I'm confused on Total Timing (I have Ignition Advance and Dynamic Advance) Knock Sum (No mention of knock in any log option) Link to comment Share on other sites More sharing options...
TPLGT Posted December 13, 2008 Share Posted December 13, 2008 DOn't forget to log a Learning View. I have the same set up with the same MAP...my logs are/were ugly. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Metal2You Posted December 13, 2008 Author Share Posted December 13, 2008 Sigh, no option to log "Learning" on the AP2 either as far as I can tell. Link to comment Share on other sites More sharing options...
TPLGT Posted December 13, 2008 Share Posted December 13, 2008 LV: http://www.romraider.com/forum/topic2772.html Infamous1 and MickeyD are awesome...they can help. PM Infamous1 and ask him for parameters to log...he has it down...GL with it. Stay in touch. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Spec B Posted December 13, 2008 Share Posted December 13, 2008 No need for AFR? With the AP2 firmware I can log Throttle Position Boost Wastegate Duty MAF I'm confused on Total Timing (I have Ignition Advance and Dynamic Advance) Knock Sum (No mention of knock in any log option) Log both ingition advance and dynamic, there should be a knock correction option? Link to comment Share on other sites More sharing options...
TPLGT Posted December 13, 2008 Share Posted December 13, 2008 I was told to always log the following: Engine Speed (rpm) Engine Load (Direct)* (g/rev) Ignition Timing (degrees) Knock Correction (degrees) Manifold Rel. Pressure (Corrected) (psi) Mass Air Flow (g/s) Primary Wastegate Duty Cycle (%) Throttle Opening Angle (%) Rehab is for quitters. Link to comment Share on other sites More sharing options...
lucas569 Posted December 13, 2008 Share Posted December 13, 2008 DOn't forget to log a Learning View. I have the same set up with the same MAP...my logs are/were ugly. did u tell mike at TA ? Link to comment Share on other sites More sharing options...
TPLGT Posted December 13, 2008 Share Posted December 13, 2008 I have had a few updates... I just reevied the newest map with the fix...yet to install that. The car feels great but the logs and LV are ugly. I am going back to my PDX Map. Less aggressive.. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Infamous1 Posted December 13, 2008 Share Posted December 13, 2008 I was told to always log the following: Engine Speed (rpm) Engine Load (Direct)* (g/rev) Ignition Timing (degrees) Knock Correction (degrees) Manifold Rel. Pressure (Corrected) (psi) Mass Air Flow (g/s) Primary Wastegate Duty Cycle (%) Throttle Opening Angle (%) Yeah try these parameters if they are available with Cobb's new firmware. But be sure to log from 2k-redline as stated above and WOT. Also if I were you I would email your logs to your tuner first so he can make any changes he finds appropriate. Link to comment Share on other sites More sharing options...
Metal2You Posted December 14, 2008 Author Share Posted December 14, 2008 There is not option to log Ignition Timing or Knock Correction with my AP v2 firmware. Link to comment Share on other sites More sharing options...
DMTaylor Posted March 1, 2009 Share Posted March 1, 2009 Updates? I'm thinking about contacting TA for a map once I get my Perrin TMIC installed. I currently have Invidia Catted DP and SPT exhaust with Cobb OTS Stage 2 map. Dave Link to comment Share on other sites More sharing options...
TPLGT Posted March 1, 2009 Share Posted March 1, 2009 Nice setup. Get a TA map. Just make sure you log and send them to Mike to ensure they're safe. Rehab is for quitters. Link to comment Share on other sites More sharing options...
