jesuscoe Posted December 11, 2008 Share Posted December 11, 2008 I am new to the forum, hoped I could get some advice! I have a 93 Legacy L AWD, recently my clutch pedal sticks to the floor if i push it all the way in..... the cable from the pedal to the adjustment thing under the hood looks fine.... anyone know what this could be? thanks a bunch!!! Link to comment Share on other sites More sharing options...
KnifeyMcShanker Posted December 11, 2008 Share Posted December 11, 2008 I had this same issue but I have a '99 with a hydraulic clutch, rebuilding the master and slave cylinder fixed it. With a mechanical clutch, the only things that could be wrong would be the springs on the clutch disk/brake or the return assist spring on the pedal. If you can, try pulling the clutch fork under the hood back and seeing if it returns by itself. Link to comment Share on other sites More sharing options...
jesuscoe Posted December 11, 2008 Author Share Posted December 11, 2008 I had this same issue but I have a '99 with a hydraulic clutch, rebuilding the master and slave cylinder fixed it. With a mechanical clutch, the only things that could be wrong would be the springs on the clutch disk/brake or the return assist spring on the pedal. If you can, try pulling the clutch fork under the hood back and seeing if it returns by itself. thats what Ive been thinking.... any idea where I can get the spring? Link to comment Share on other sites More sharing options...
KnifeyMcShanker Posted December 12, 2008 Share Posted December 12, 2008 Junkyard, auto parts store might have one that fits. Just bring in the old one for comparison. Springs don't really go bad though so make sure that's the issue before dumping money onto it. It may have just slipped off its seat or something. Link to comment Share on other sites More sharing options...
