addison Posted December 10, 2008 Share Posted December 10, 2008 i have a local friend selling his sway bar and endlinks off of his 08 sti which were designed for the 05+ legacy but happen to fit his car. the endlinks have a screw and are adjustable as seen in the picture. how are these supposed to be adjusted for the legacy? is there a certain length they need to be screwed in or should it just be adjusted to be the length of the stocker? http://img.photobucket.com/albums/v409/matthuntman/IMG_0832.jpg Link to comment Share on other sites More sharing options...
itsme Posted December 10, 2008 Share Posted December 10, 2008 just use your stock endlinks. Stock will last much longer. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Gary Bechtold Posted December 10, 2008 Share Posted December 10, 2008 itsme, seriously, go with the stock endlinks with aftermarket sways? Just want to know. Thanks. Link to comment Share on other sites More sharing options...
itsme Posted December 10, 2008 Share Posted December 10, 2008 Yes I still have my stock endlinks. I have whiteline f&r adj. sways , KW v.2 coil overs. I never had a clunk or crunch like you get with aftermarket links. Save your money and buy the poly LCA bushings. They do alot more then endlinks . I have had my sway and been lowered for over 3yrs and never had a problem with stock. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
addison Posted December 11, 2008 Author Share Posted December 11, 2008 what size sway? do you track at all? ill be running a 25mm sway and it will get the shit driven out of it. Link to comment Share on other sites More sharing options...
itsme Posted December 11, 2008 Share Posted December 11, 2008 what size sway? do you track at all? ill be running a 25mm sway and it will get the shit driven out of it. I don't track my car. There alot of members that track still use stock links. Why is that so hard to believe? The only people I see that say you need new links are people that bought them and need to justify it or sell them. You know what buy the endlinks Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
BigBad Posted December 11, 2008 Share Posted December 11, 2008 Yes I still have my stock endlinks. I have whiteline f&r adj. sways , KW v.2 coil overs. I never had a clunk or crunch like you get with aftermarket links. Save your money and buy the poly LCA bushings. They do alot more then endlinks . I have had my sway and been lowered for over 3yrs and never had a problem with stock. +1 save your money, I've been running stock endlinks with cusco sways for several years now. Link to comment Share on other sites More sharing options...
