RustyShackleford Posted December 10, 2008 Share Posted December 10, 2008 I'd like to (rather dramatically) increase the brightness of my map lights (the little guys right behind the top of the windshield). With the moonroof, the dome light is so far back as not to be that useful, plus it's not that bright either. I find that I simply don't have NEARLY enough illumination in the cabin; I've actually run down the battery by exiting the car not realizing the map lights are on ! I suppose it's possible I'm going blind or that the lights do not contain the proper bulbs, but I doubt it. Any ideas for how to improve the situation ? LED conversion bulbs that fit ? Link to comment Share on other sites More sharing options...
dragonman586 Posted December 10, 2008 Share Posted December 10, 2008 Search around dealextreme.com I'm sure they have something. Link to comment Share on other sites More sharing options...
kjiz Posted December 10, 2008 Share Posted December 10, 2008 You can also take it apart and cut the shield covering the lense so more light comes through. Link to comment Share on other sites More sharing options...
icy Posted December 10, 2008 Share Posted December 10, 2008 You may try this mod. http://legacygt.com/forums/showthread.php?t=23139 I wired it so all three lights come on at the same time. Maybe not a dramatic as you are looking for but it certainly lights up the interior better than just one of the three lights. Link to comment Share on other sites More sharing options...
snow05gtRI Posted December 10, 2008 Share Posted December 10, 2008 http://www.legacygt.com/forums/showthread.php?t=60259 this place sells 'em in sets. Link to comment Share on other sites More sharing options...
RustyShackleford Posted December 10, 2008 Author Share Posted December 10, 2008 http://www.legacygt.com/forums/showthread.php?t=60259 this place sells 'em in sets. Mucho dinero ! Thanks for the suggestions folks. Maybe I'll first try the el-cheapo LED units from dealextreme.com ... Link to comment Share on other sites More sharing options...
Gire Posted December 10, 2008 Share Posted December 10, 2008 search fastwrx.com for their LED interior kit. Grimbeaver here has the kit and I've seen it at night in person, WOW! Big difference. Edit- here, I'm in a generous n00b helping mood today. http://www.fastwrx.com/ledinli.html Link to comment Share on other sites More sharing options...
Detslider Posted December 11, 2008 Share Posted December 11, 2008 I've got the Mach V (fastwrx) LED lights in mine and they are super bright. A great mod! Link to comment Share on other sites More sharing options...
RustyShackleford Posted December 12, 2008 Author Share Posted December 12, 2008 Thanks for all the suggestions, folks. I removed the lens to have a look at the existing situation - a couple of short length "festoon" bulbs. Here's the thing. The lens piece just has two very small holes - maybe barely a square inch - one per map light. With the lens removed, the existing bulbs are plenty bright enough ! I guess the reason they did it this way is to avoid blinding the driver. I'm not sure it'd be too hard to increase the hole size - the lens is two pieces, a clear layer, and then an opaque piece with the holes cut in it; so just de-attach the opaque piece and cut the holes out bigger. Maybe just enlarge the driver side one, since the driver shouldn't be looking at stuff with the map-light anyhow, and leave the pax side one as is, so if the pax is looking at something, it won't blind the driver. When you really need to light up the inside of the car, use the driver side one. Another option might be a dimmer, or at least a two-speed switch. I wonder if the fastwrx ones are designed for the adhesive LED panel to fit the very small existing hole ? Link to comment Share on other sites More sharing options...
EquinnoxX Posted December 14, 2008 Share Posted December 14, 2008 +1 for the Mach V ones. They're awesome. I have the map and puddle lamps and get compliments all the time. The lights are actually attached to a board of LEDs that fit snugly in the spot up there. The actual 'light bulb' is tapped with a wire and sits behind the LED board. I'm pretty sure thats how they were setup ... its been awhile since i last looked at them. Link to comment Share on other sites More sharing options...
NSFW Posted December 17, 2008 Share Posted December 17, 2008 +1 for Mach V. Link to comment Share on other sites More sharing options...
