lepich Posted December 10, 2008 Share Posted December 10, 2008 Probably this is really an easy Q, but I can't find an answer so far. What Table A and table B means on our ECU (romaraider editor) Which table car will be using? Particullary Initial Wastegate duty: I've altered table A after replacing a restrictor pill on my car, forgot to change table B. Which one is running on my car? Thanls. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
lepich Posted December 10, 2008 Author Share Posted December 10, 2008 I can't believe nobody knows... I looks like something obvious, so everybody should know. Except me :-) There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
SonOfBadBoy Posted December 10, 2008 Share Posted December 10, 2008 Here is an easy way to tell which of the tables your car uses.... Change the WD cycle table x.5 on A load the map and drive --if your car acts different thats the table to change if not change B then drive again and you will eventually figure it out. Link to comment Share on other sites More sharing options...
lepich Posted December 10, 2008 Author Share Posted December 10, 2008 yes, I did this way. My car used A table. But it should be some logic, right? When and why car will switch table (if it possible for ECU to switch), or it fixed, just always A or B for a particular car? There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
SonOfBadBoy Posted December 10, 2008 Share Posted December 10, 2008 I think it would switch if it goes into limp mode for a base reference point. other than that I dunno why it would switch. Link to comment Share on other sites More sharing options...
lepich Posted December 10, 2008 Author Share Posted December 10, 2008 Looks like it use B tables: boost, wastegate.. Just drove around, according to logs was hitting 12 psi boost , which is B table (17.9 target in A table). Does it mean car in a limp mode? why? I've reset the ECU , same thing. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
