partyman111 Posted December 9, 2008 Share Posted December 9, 2008 I have a 2001 Subaru Legacy Gt and for some reason my reverse will not stay in, It drives to about 2500-3000 RPMs and then pops out. Just wondering if this happened to anyone else and what a common problem may be. Also this morning I hopped in my car too pull it out of my garage after it was warming up for a good 5-7 minutes i put it in reverse and the sunroof opened ALL THE WAY. When i tried to push the button to close it nothing happened, where i live we have about 3 ft of snow already and were in a winter storm watch as we speak. I managed to pull the light cover closed to keep the snow out of the inside thankfully but that is going to get damaged for sure . I'm headin to the subaru Dealer after a while to see if they've seen this problem and if there is something they can do. Thanks for anyone that has any advice or comments. Link to comment Share on other sites More sharing options...
ehsnils Posted December 9, 2008 Share Posted December 9, 2008 First question is: Is it MT or AT? Probably just a linkage adjustment needed - unless you have something stuck in the linkage. (Dead rat? ) Just make sure that the engine supports are OK too, because if the engine/gearbox is out of place the linkage may also get it wrong etc... Link to comment Share on other sites More sharing options...
android25ua Posted December 9, 2008 Share Posted December 9, 2008 do you have a remote starter? on manual cars they have to install it in a way it electronically verifies that the car is in neutral before it starts. If you were getting it done at a cheap place - they could of messed up your electronics. That again if you have a remote starter Other than than i dont see any possible connection between a sunroof and the gearbox Link to comment Share on other sites More sharing options...
