Anyone ever ran an 18x9, 35mm offset
Tuned200
Posted
As it says, im looking at a set of used wheels, they are 18x9 35mm with 235/40/18 tires. Not sure if they will work on the LGT or not and may considerthem for the forester XT, but who knows. Thanks.
I did search and I read the faq above but I have no understanding of wheels/offsets.
Posted
you would probably have to roll the fenders. As everyone told me, as long as you are ok with the added wear on the wheel bearings. But i am running a 17x7.5 ET36. fronts stick out abotu a 1/4 of an inch. the rears are flush with the fender. personally i would say if you are ok with them sticking out, hey.
OTM.
Sorry I didn't mean to start a war which mainly forum people is all about ;).
Posted
Are they the same wheels you had back when we swapped trunks? Im not sure if I want to go wit hthe 18x9 35mm but the price is good and they are my favorite wheels by rota(G-Force, steel grey)
The tire also has me concerned, the 235/40/18...Man, im stumped
Here they are on a 02 wrx slammed on coilovers
http://i264.photobucket.com/albums/ii175/nmb1bacardi/IMG_0861.jpghttp://
Posted
no, these are newer wheels.
http://i72.photobucket.com/albums/i171/Crucifix79/wheelsIII004.jpg
http://i72.photobucket.com/albums/i171/Crucifix79/wheelsIII005.jpg
http://i72.photobucket.com/albums/i171/Crucifix79/wheelsIII007.jpg
thats alot of offset for a 9inch wheel though. But everyone told me i would rub etc, when i would run this setup as well.
OTM.
Posted
on tein H techs.
OTM.
Posted
You do know the g-Force are available in 18x8.5 in the proper offset for our cars?
Edit: I did nto see these were used and for a forester. But either way 18x8.5 is available.
Posted
slammed? you called that slammed? that's not slammed.. you need to check out http://www.hellaflush.com and see really tucked cars.
As for the fitment, if my guide say that it doesnt fit, it doesnt fit without modifications.
You may catch up on reading my FAQ again. Go and look at your rim width, then look to see if your offset fall in the range I specify, it's that simple. If it does, then it should fit as long as you choose a tire that fits it properly.. if it isn't listed, keeping looking for other rims and save your money. Last thing you want to do is to shell out more money to replace a fender or wheel bearing or whatever else you may beat up just because you decided to be really budgeted on a set of Rotas..
Keefe
Posted
...but I have no understanding of wheels/offsets.
How about bolt patterns and hub size?
It's a good idea to get (only) wheels that are right for your car. These 18s are not only two inches wider than stock wheels, but the offset puts them a half inch farther outboard. And you didn't say anything about the other specs that may also be wrong.
Make sure to check everything carefully before investing -- and don't just assume that they'll fit your Forester, either. HPH
Posted
Is this true?
I know there are a few people who are running Exel TZ-10 in 18x7.5 and those are supposedly +35 offset. Looking at your sticky, this wheel should not fit. Yet there are at least 2-3 people on this forum using that wheel.
