crazyjay1089 Posted October 30, 2008 Posted October 30, 2008 So a couple weeks ago, I noticed that there was a bit wet in the passenger seat footwell. Thought nothing of it since it had rained the day before (wet passenger feet?). But then a couple days later I noticed a collection of water that I could actually see in the footwell. It had been humid, but hadn't rained recently. So I investigated. Came up with nothing. A couple days later I drove right after a rainstorm and noticed water was collecting while I was driving, noticeably dripping down from under the glove compartment. Once I got home I pulled out a flashlight and looked behind the glove box from underneath. There was a drip coming from right where the air conditioning is housed. I felt around but couldn't exactly find the source. I was in a bit of a rush and needed a quick fix. I found the hose where moisture usually drips from, got my air compressor, and blew some air up the hose. I heard a gurgling and then dark water gushed out. Haven't had any water problems since.. though I'm worried about where all that blockage gunk ended up. Any thoughts? Anyone have a similar problem?
Yamarocket630 Posted October 31, 2008 Posted October 31, 2008 check the a/c case drain tube. it's clogged or disconnected.
