Retune after replacing stock injectors with new?
derffred
Posted
So, here's a small story. At 60K I replaced my spark plugs with NGK 1-Step Colder.
And it seems ever since, I've been getting a Check Engine light every couple weeks with codes for a miss on Cylinders 2 and 4 (just the codes, the engine runs fine)... I pulled out the plugs, checked them, regapped them (they were okay) and put them back in.
Meanwhile, I got my car tuned at Precision while this was going on. So my question is, since the CEL still comes on intermittently, and IF my injectors are no good, would I have to get a retune with the new OEM injectors? If they tuned my car with a "bad injector" and it ends up getting replaced, would it affect the A/F if I don't get it retuned?
Posted
If your car was tuned w/ a bad injector then you need to be retuned.
FWIW I put in cleaned and flow balanced stock injectors in my car (originals were just fine), noticed no difference in learned AFR trims.
Posted
I used 1-Step Colder NGK from JSC-Speed's website.
I pulled them out about a week before my tune to check the gap and they were okay. I also swapped my coils from 2&4 to 1&3
Posted
When I was getting tuned, the tuner was having a hard time getting my LTFT and STFT in the right parameters, they took out my MAF and cleaned it and finally got them right after about 45 minutes.
