Dp Catted or uncatted?
foolds
Posted
For you Colorado guys that have to pass the envirotest, do you run catted or uncatted DP's? I'm thinking about going stage 2 and am really trying to decide what the best way to do it is. I have a 05 5eat wagon.
Posted
If you go for the test you will fail the visual test period. As far as the smog test I am pretty sure you will fail that as well. Just get the catted DP but, be prepared to put on your stock DP when you go for the test. They are getting stricter every year.
Posted
if your car was brand new, I would say go catless, since you have 4 years before you need a emmisons test. Since you have a 05, a emmisons test should be due pretty soon, so I would recomend a catted downpipe. With a catted downpipe, you will pass the roadside emmsions tests.
Posted
The roadside tests are more stringent than the regular test facilities are. There are more and more people failing with just one cat. If you want to read more about it check out the thread over at AWDPirates.
Just keep your stock DP and when you have to go in for your test just put it on and you will pass no problems.
Posted
Can you post a Link? Catted DP would be pretty much useless if it can't pass the emission test.
+1. It's ~1/2 hr job on the LGT.
I do the same thing on my Z every 2 years.
Posted
I drive right past the road side trucks at least 2 times a week. my office is right by one of there favorite spots to hang out. I have about 1.8 years before I have to pass e-test again.
Posted
They passed a new law that allows the road side test vans to flag cars that fail the test. They will send you a summon to come in for testing if you get flagged by the van, even if it's not yet time for your emission test.
Posted
The cat in the UP does it's thing during cold startup. Once the engine warms up the cat in the UP really doesn't help much. The stock DP has 2 cats but high flow aftermarket DP usually only has one cat. From what enthusiast is saying people are seeing one cat aftermarket DP failing the emission test. I haven't read the awdpirate threads that enthusiast is referring to, but if you are are worrying about DP's then you should probably look them up.
Posted
^ and from what I can remember, don't put your car in neutral and coast pass the emissions van either. A good old take your foot off the gas is better.
(right?)
brian
Posted
^yup, as long as your rpm is above idle or higher to be safe. Coasting in gear means you are not burning gas, no gas equals no emission.
Posted
Both our cars have been through the drive by test many times and have never been notified of failure, the 05 STi is up for its sticker next year (will have had for 5 year at that point) and will see what happens. The 05 GT will be due in 2010.
STi has a catted MRT turbo back and the GT is running a catted Cobb down pipe rest is stock exhaust.
Catted pipes made right don't cost enough power that you'll ever notice, but if you want attention then go catless.
Parker
