Prodrive EBCS and Labonte BBK Help
taskforcefreddy
Posted
Hey everyone,
I'm installing my Prodrive EBCS (on the left) and Labonte Boost Bypass (on the right) and Failsafe kit in preparation for my tune on the 10th and am having trouble figuring out how to plumb my hoses to make these things work in harmony. I've found some great info on installing the Prodrive EBCS and that in itself would be easy however the instructions that came with the BBK are confusing. Am wondering if someone could PowerPoint some lines on the photo below? Thanks much.
http://i263.photobucket.com/albums/ii140/taskforcefreddy/Subaru%20Legacy%20GT/DSCF1813.jpg
Posted
Hey guys...
BBK= The Labonte Boost Bypass Kit. And I concur. It looks just like the prodrive EBCS and does basically the same thing only it gets its signal from the WI Controller
As far as they instuctions on the BBK, very vague (spell?) to the point of confusion. I will email the guys at Labonte with the same pic to see what they recommend.
Thanks for looking.
Posted
O, I get it. Instead of putting the $$ for an aftermarket ECU that could handle Water Injection, you get a second EBCS controlled by the WI computer to raise boost when it sprays.
Complicated setups only lead to big power, followed by a very big, complicated failure.
As far as setting that up, you need the BBK to be piped in BEFORE the EBCS so that it could further raise boost beyond what the EBCS is letting it.
Having two solenoids in series is gonna be a serious tuning nightmare to get everything to work right together
(Updated 8/22/17)
2005 Outback FMT
Running on Electrons
Posted
Trying to do this with an interrupt style boost control system isn't going to work, doing it with a bleed type of system (like the stock system) will work fine. I would toss the EBCS and use the stock solenoid in stock configuration. Take the BBK (I love acronyms, it makes everyone sound so smart and in touch :lol: ) and set it up so that when it is triggered due to the failsafe - it sends boost pressure directly to the wastegate.
Posted
Listen to rao, not weiner.
We just described two ways of doing it.
1 (the way i described) adds boost when the WI is spraying
2 (rao's meathod) cuts boost if the WI fails
they acomplish the same thing
(Updated 8/22/17)
2005 Outback FMT
Posted
You describe how you propose tuning your method, if you can come up with something that actually realistically works (and has been done before) I will be shocked.:eek:
The way rao said makes sense.
Posted
Thanks for all the input. In times of need, I have a bad habit of trusting my tuner. I called my guy at IA performance in Tucson (the most highly regarded tuner in my area AFAIK) and told him I will be upgrading my meth kit to incorporate the Labonte Failsafe. His recommendation was to use both the BBK (it's not just an acronym it's the actual name of the product) and the Prodrive EBCS. I have had zero reason to doubt this guy in the past. The vague Labonte directions does give instructions on how it can be used with a 3-port EBCS, so it is possible. Is there reason for concern?
Posted
I took a picture of the Labonte instruction sheet. I would be doing install B. If this makes sense to you, you're a better man that I. Thanks again.
http://i263.photobucket.com/albums/ii140/taskforcefreddy/Subaru%20Legacy%20GT/DSCF1814.jpg
Posted
Makes sense to me.
When the 3-port EBCS is being activated (not sure what to call it, but when it is trying to raise the boost) the port from the turbo (boost source) to the WG actuator is blocked, but the port from the WG actuator to the BBK is open.
If the alky system's failsafe is being activated it will just reroute the pressure back into the EBCS, causing the car to run at WG srping value boost only.
If the alky system's failsafe is not being activated then it will allow normal funcitoning of th EBCS to raise boost to tuned level.
Just hook it up like it says.
If you are still unsure then get a 12v source and run through the different scenarios. Then blow in the vacuum lines to see if it does what you think.
Posted
^^^ So, based off your guidance and my ability to deduct, this is how it should be hooked up...
http://i263.photobucket.com/albums/ii140/taskforcefreddy/Subaru%20Legacy%20GT/EBCSandBBK.jpg
Posted
LBGT,
Yeah, if I was installing just the EBCS, that's exactly how it should look however the BBK instructions make no reference of sending a line to the intake. What do you think?
Posted
I can't say I know for sure how the BBK works (I don't have one). When I posted the pic of the plumbing for the pro-drive EBCS I did so becasue just the pro-drive plumbing looked off (wrong ports in wrong spots).
This is how I think the BBK would work (pretty easy to check with a 12v source: (red is pressure, blue is blocked port)
0% WGDC BBK active (by active I mean it is cutting boost)
http://i248.photobucket.com/albums/gg194/littlebluegt/0WGDCBBKactive.jpg
0% WGDC BBK not active
http://i248.photobucket.com/albums/gg194/littlebluegt/0WGDCBBKnotactive.jpg
100% WGDC BBK not active
http://i248.photobucket.com/albums/gg194/littlebluegt/100WGDCBBKnotactive.jpg
100% WGDC BBK active
http://i248.photobucket.com/albums/gg194/littlebluegt/100WGDCBBKactive.jpg
What is wrong with that?:confused:
To rao: if I have some info wrong, I would like to know, as I think you may have some experience with this.
FWIW I just use a solenoid with my alky system, when it senses a problem it just disrupts the signal going to the EBCS. Much easier IMO.
  • 2 months later...
