boxkita Posted June 7, 2021 Share Posted June 7, 2021 I'm a first time Subaru owner and new to the world of tuning. I'm super excited to learn about these cars and begin mods on my new girl. I knkw nothing, so I ask every 2.5lgt owner I see, sti as well. Everyone is quick to share. So I stage 3 clutch Perrin intake A chrome looking computer box under the hood on pass side BC coilovers Cobb sway bars I'm looking to make some mods within the month. New intake and tune. What do you suggest? Sent from my SM-G991U using Tapatalk not a honda. don't change intake. get all the maintenance done first. make sure it stays running through the first oil change. if you have no idea when the timing belt was done, that's a good first step Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
lagwagon Posted July 27, 2021 Share Posted July 27, 2021 Hopefully somebody can help with an answer, I have searched but haven't found this - if I use the ignition retard feature from the menus in the Accessport, does that setting get held through key on/off cycles or does it reset each time the car is shut off? Also, does it reset each time that menu section is accessed? Every time I go to that section is shows zero, making me think it resets at every key cycle and also every time the menu is accessed. Thanks Cobb AP gurus! Link to comment Share on other sites More sharing options...
COBB Tuning Posted July 28, 2021 Share Posted July 28, 2021 Hopefully somebody can help with an answer, I have searched but haven't found this - if I use the ignition retard feature from the menus in the Accessport, does that setting get held through key on/off cycles or does it reset each time the car is shut off? Also, does it reset each time that menu section is accessed? Every time I go to that section is shows zero, making me think it resets at every key cycle and also every time the menu is accessed. Thanks Cobb AP gurus! Hey there! Changes on the AP are made to "Real Time" data and will persist across key cycles. Those changes will reset to the map default at an ECU reset or map change. Marshall@COBB Link to comment Share on other sites More sharing options...
lagwagon Posted July 29, 2021 Share Posted July 29, 2021 Thanks Marshall! Link to comment Share on other sites More sharing options...
