NSFW Posted December 18, 2008 Share Posted December 18, 2008 (edited) Log: Engine Speed Engine Load Manifold Relitive Pressure (corrected) Total Timing Knock sum Maf (g/sec) Throttle opening Do a WOT run in 3rd gear from 2000-redline on a flat road. Nit pick: If you log Load, RPM, and MAF, use the "calculated" load parameter. That way you're really only logging RPM and MAF, and the logger is calculating load from them. It's one less parameter going over the wire, which means slightly faster logging. Do CAN cars log rapidly enough that this is a non-issue? Edited December 18, 2008 by NSFW typos Link to comment Share on other sites More sharing options...
NSFW Posted December 18, 2008 Share Posted December 18, 2008 Do that and take a learning view.... http://www.romraider.com/forum/topic2772.html Or add the following to the mix IAM Feedback Knock correction Finelearning knock correction If you're logging total timing and knock sum, and taking LV snapshots, why bother adding IAM and the knock corrections? Link to comment Share on other sites More sharing options...
Infamous1 Posted December 18, 2008 Share Posted December 18, 2008 If you're logging total timing and knock sum, and taking LV snapshots, why bother adding IAM and the knock corrections? I was refering to running the posted parameters and a LV snapshot or the adding knock corrections to the mix without the LV snapshot. Link to comment Share on other sites More sharing options...
NSFW Posted December 18, 2008 Share Posted December 18, 2008 I see, that makes sense. Link to comment Share on other sites More sharing options...
sugawi Posted December 18, 2008 Share Posted December 18, 2008 Thanks for all help. I just went ahead and posted new thread: http://www.legacygt.com/forums/showthread.php?p=2215605#post2215605 Some of the values I could not find, but thanks to search button and infamous1 post I found about that they appear after you connect everything together. Link to comment Share on other sites More sharing options...
DrGrip Posted December 24, 2008 Share Posted December 24, 2008 (edited) So where's the best place to buy the cable? Here? http://www.autonostics.com/product.php?productid=2&cat=2&page=1 $15 but shipping makes it $20. I found some on ebay...some have a silver USB cable, some have the blue...no mention of brands though. Can someone who bought it off of ebay point me to one they have working? Seems to be cheaper @ teh fleabay. Edited December 24, 2008 by DrGrip Link to comment Share on other sites More sharing options...
FASTONE Posted December 24, 2008 Share Posted December 24, 2008 I also want to know, because Tactrix is like $180.. Link to comment Share on other sites More sharing options...
PhilT Posted December 24, 2008 Share Posted December 24, 2008 So where's the best place to buy the cable? Here? http://www.autonostics.com/product.php?productid=2&cat=2&page=1 $15 but shipping makes it $20. I found some on ebay...some have a silver USB cable, some have the blue...no mention of brands though. Can someone who bought it off of ebay point me to one they have working? Seems to be cheaper @ teh fleabay. That's the one, the blue one. Make sure you download the driver for it too. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
lepich Posted December 24, 2008 Share Posted December 24, 2008 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=260297054101 this is mine.. 14 shipped, from Hong Kong There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
sugawi Posted December 24, 2008 Share Posted December 24, 2008 I just got cheapest one from Hong Kong for $12 (silver one) and it works fine. I tried to use drivers from the link on this thread but had no luck. I just used drivers that came with the cable and it works fine. I used that cable with Learning View, RomRaider and EcuFlash. I think that all will work as losng as they are the same type: VAG COM 409.1 FTDI Chipset based design. Here is my thread from tuning: http://legacygt.com/forums/showthread.php?t=102266 Link to comment Share on other sites More sharing options...
DrGrip Posted December 24, 2008 Share Posted December 24, 2008 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=260297054101 this is mine.. 14 shipped, from Hong Kong Does it work with the downloadable drivers or did you use the included CD? It's sort of a necessity to me for it to work with downloadable drivers since my netbook has no optical drive. I guess the silver one is a no go now... Link to comment Share on other sites More sharing options...
lepich Posted December 24, 2008 Share Posted December 24, 2008 As i remember (short memory, you know..) i've used downloadable driver, but manually selected which *inf file to use, pointing in "update driver" page.. Without this, it used wrond driver, does not work. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
DrGrip Posted December 24, 2008 Share Posted December 24, 2008 (edited) As i remember (short memory, you know..) i've used downloadable driver, but manually selected which *inf file to use, pointing in "update driver" page.. Without this, it used wrond driver, does not work. Awesome, thanks...how long did it take to get to you from HK? I'm thinking of paying a bit more and getting it from the autonostics website, as they'd ship from FL. Edited December 24, 2008 by DrGrip Link to comment Share on other sites More sharing options...
lepich Posted December 25, 2008 Share Posted December 25, 2008 For me it was more then a week, about 8-9 days total. If you need it faster, get from FL, not really big money :-) I was busy anyway, so I've ordered from HK There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
FASTONE Posted December 26, 2008 Share Posted December 26, 2008 I got one from here, shipping from US. http://cgi.ebay.com/ebaymotors/USB-Vag-Com-Cable-diagnosis-Scanner-VW-Audi-VagCom-OBD2_W0QQcmdZViewItemQQ_trkparmsZ72Q3a543Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem270321556708QQitemZ270321556708QQptZMotorsQ5fAutomotiveQ5fTools $22 shipped Link to comment Share on other sites More sharing options...
Scooby2.5 Posted December 26, 2008 Share Posted December 26, 2008 got to love ebay. Says free shipping but they charge $22 for a $15 cable. They should just say shipping included! Link to comment Share on other sites More sharing options...
lepich Posted December 27, 2008 Share Posted December 27, 2008 why you think it is $15 cable? :-) it may cost from $7 to $25, and production cost , I think, is about $4... There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted December 27, 2008 Share Posted December 27, 2008 Because I purchased it from the autonostic website see post 12 Also post 106 I just think it is funny that people on ebay run the cost of stuff up and then say FREE SHIPPING. When in fact the shipping is already added into the price. Link to comment Share on other sites More sharing options...
lepich Posted December 29, 2008 Share Posted December 29, 2008 Different merchants has a diff pricing, this is what i meant. I've got this cable for a $8 + shipping, does this mean autonostic has wrong cost? Nope. same for a guys with free shipping, as it is really free:-) Price is different. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted December 29, 2008 Share Posted December 29, 2008 Shipping is hidden cost, many times with the words Free Shipping attached to it, is my point. Link to comment Share on other sites More sharing options...
Spec B Posted December 30, 2008 Share Posted December 30, 2008 I just ordered this cable (I had been using my friends Tactrix 1.3). Is there any advantage to the Tactrix or are they essentially the same thing? Link to comment Share on other sites More sharing options...
FASTONE Posted December 30, 2008 Share Posted December 30, 2008 I just got my Ebay cable to work, i got it to work on both xp and vista, in xp use the drivers that are on the first page and make sure you update the java, even if you have the latest version just reinstall, mine was doing "please connect the cable", and "connecting to ECU" on the right top corner, in vista also had to update java, and install as admin, no drivers needed, windows update installed the drivers. tried version 0.5.0 and worked great, tried new 0.5.1 and i had to install ECU defs and Logger file from the romraider web site. IT WORKS So far best $20 spend. Thank you Link to comment Share on other sites More sharing options...
snow05gtRI Posted December 31, 2008 Share Posted December 31, 2008 I just ordered this cable (I had been using my friends Tactrix 1.3). Is there any advantage to the Tactrix or are they essentially the same thing? supposedly more difficult to flash with the autonostics cable than the tactrix. i havent tried either, but the autonostics works great for logging... Link to comment Share on other sites More sharing options...
lepich Posted December 31, 2008 Share Posted December 31, 2008 Cable is just a cable. No difference after you setup a driver. Driver may be more difficult, but not a cable. Does not matter what cable you are using after connection was established. Have a great NEW YEAR, my friends! There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
qikslvr Posted January 1, 2009 Author Share Posted January 1, 2009 Sorry I've been MIA for the last few weeks and haven't been in to check my threads. Looks like the community is getting the hang of this and that's great to see. As stated earlier; you should be able to use any application with this cable once the drivers are properly installed and the communications settings are configured in the apps. The biggest issue with reading/flashing ROM images seems to be related to version of ECUFlash you are using. I use version 1.34 and have had no issues(send me your e-mail and I can send it to you as a .zip). Again, It's just a matter of getting the communications settings dialed in and everything else should follow. Let's kick this pig! Link to comment Share on other sites More sharing options...
