Active AWD 4EAT - 1ST & Rev Gear Torque Split
k8ctt
Posted
I have read (unreliable source) that the Active AWD 4EAT transmission actually provides a 50/50 torque split in 1st and reverse and changes to the normal 90/10 split after shifting into 2nd gear under normal acceleration and road conditions. Is this true?
Does this have anything to do with the 'relay clicking noise' that I hear when the car almost comes to a complete stop? The noise appears to be coming from the center console.
2007 Legacy 2.5i Limited
Posted
My understanding is that the 50/50 split only occurs when you manually put the transmission into '1', but not when in D and the transmission is in 1st for normal driving. I'm honestly not sure though.
Posted
The relay clicking noise I've had on other previous cars, to put it in simple terms it's the switch-thingie-do that when you're rolling it will prevent you from slamming the gear selector in R or P. You hear it click when you're almost stopped and after you do, you can drop it in P or R. Far as my dealer(s) and I figured it, basically the switch gets normal "wear and tear" and, although you can't hear it at first, it will get noisy with time. Guess the LGT has the same crappy cheap part my 3rd gen auto Altima did. They both started clicking at around the same mileage, although the LGT is not nearly as loud or obvious as the Alty was.
Later edit: heh, should have read the thread title more careful ... You are talking about the 4EAT. Edited my reply.
What's your source? Could be right, could be wrong.
  • 1 year later...
