98 LGT Limited Wagon
speresy
Posted
Looking at this 1998 Legacy GT Limited Wagon. Its a 5spd, 95,XXX miles, etc.
Anything in particular to look out for? Plan on getting a carfax and copy of the mechanics report. Thanks for the help
http://images.autotrader.com/images/2008/5/15/244/713/7148481952.244713121.IM1.MAIN.565x421_A.562x421.jpg
http://images.autotrader.com/images/2008/5/15/244/713/7148481953.244713121.IM1.03.565x421_A.562x421.jpg
  • 2 weeks later...
Posted
Head Gaskets:
This generation of LGT is prone to head gasket failures. This is a very expensive repair so if you don't have proof that both head gaskets were replaced then use that in your negotiation on price, but budget $1500 for this repair.
The nasioc forum has more info on this 2nd generation LGT than this forum does: http://forums.nasioc.com/forums/showthread.php?t=1561981
Also, with that mileage, it's due for a timing belt replacement soon at 105,000 miles. Here is the maintenance schedule:
http://www.subaru.com/owners/schedules/index.jsp?navid=SCHEDULE_1998
Regards,
Jim
Posted
Along with the timing belt that Jim mentioned, it'll also need a valve adjustment.
Even if the HG has been replaced, it doesn't mean it won't go again. I know of a car that had them replaced at ~60K and like clockwork, it started showing signs of a leak again at ~120K.
Posted
I replaced my HG at 140,000 miles and they were fine at 189,000 when we sold it. If the repair lasts less than 100,000 miles it probably wasn't done properly - the heads warp quite a bit and must be machined.
The big thing to know is that this was just a trim level - a Legacy wagon with some options and an Outback hood and 16" wheels. There are few ways to improve performance, none economical. It is a practical, fairly durable wagon but all it has in common with the Gen III turbocharged cars is the letters GT.
Who Dares Wins
スバル
