05 5MT Light chirping Noise?
wsf0817
Posted
The other day I noitced a very light chirping noise when I would push in the clutch. It occurs about half way through the pedal engagement. It is related to the clutch engagement and not the actual gear shift. When the car warms up it will go away. Its not the pedal because if I stop the throw mid-way the noise will persist until I push it the rest of the way in or let it out.
Any ideas? TO bearing? Clutch on its way out?
Thanks!
  • 4 weeks later...
Posted
Yea same here, ive been noticing it a couple of weeks back. when i first back out of my driveway in the morning, since the walls are close enough, the noise are reflected back. This only happens when i let the clutch out halfway and I dont notice it when its warmed up. any ideas?
Thanks
Posted
Me too. It seems to be temperature related as I never notice it at my underground garage at work that is still 75F. I only notice it on mornings with overnight temperatures under 50F, and it goes away quickly.
I don't think I'm going to panic.
Posted
Noticed the same noise on my '08 WRX. It has only started happening in the last month or so. If it gets down near 60 at night and there is any humidity it'll do it for 5-10 mins in the morning on startup. I'm not all that concerned about it. Nothing I can really do until something actually goes wrong or becomes seriously noticeable anyway.
Posted
i would assume a chirp, on the clutch pedal throw is going to be a Throw Our Bearing issue. Im not expert on LGT's, but that would be my assumption on any manual tranny
Posted
^^^ This
My stocker was chirping for a few thousand miles before I replaced the clutch with an ACT unit. The throw out bearing was shot.
  • 5 weeks later...
Posted
Any one above have any updates.
Engine Build - Click Here
