John_2001 Posted September 1, 2008 Share Posted September 1, 2008 I was replacing the spark plugs on my 1991 legacy (non turbo) and I apparently shorted out the two wires going to the drivers side front fuel injector. One of the wires had a bare spot on it, so I may have grounded it out with my ratchet. Now the car won't start. It will crank just fine but has no fire. I checked both fuse boxes and I can't find a blown fuse. I looked for burned wires as best I could but didn't find any. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Justin Forsythe Posted July 31, 2011 Share Posted July 31, 2011 First thing I would do would be to check the trouble codes, there are instructions everywhere in forums to do this for the OBDI. make sure the car still has spark coming from the coil. you can test by removing spark plug from the block, reattach to wire, and grounding the combustion end of the plug, turn it over, check for spark between the electrodes of the plug. usually requires 2 people. Link to comment Share on other sites More sharing options...
Osei Posted August 1, 2011 Share Posted August 1, 2011 Also check the relay and fuses for the fuel pump. You may have shorted them out. see http://www.main.experiencetherave.com/subaru_manual_scans/ check appropriate sections. O. Link to comment Share on other sites More sharing options...
kateviliams Posted August 5, 2011 Share Posted August 5, 2011 check the fuel pump and spark between electrodes. Link to comment Share on other sites More sharing options...
