boxkita Posted May 28, 2019 Share Posted May 28, 2019 202216FA000 - Taper Boss to integrate stock Ball Joint with MevoTech LCA assembly. also need this to work with OEM specB LCA arms that left that part on the seller's car. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 29, 2019 Share Posted May 29, 2019 Thanks goes to Outback2.5XT-05 as he threw out this PN on the What did you do to your outback thread. Now I need a new dust cap for the front strut perch since the shop lost one. 20326AA120 for the dust cap. Link to comment Share on other sites More sharing options...
Mluetch Posted May 29, 2019 Share Posted May 29, 2019 thanks, this list is a huge help! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 30, 2019 Share Posted May 30, 2019 Does anyone know of a Silver Center cap for Spec B, that either has the logo and says spec b or Subaru with spec B on it as well. I could have sworn somewhere on the net I saw the legacy silver center cap, with spec B on it . Does this really exist or is it an aftermarket thing? Just stumbled onto this thread, I'll say you saw a aftermarket cap. I swap center caps from my two sets of wheels for both cars all the time. Just have the Subaru emblem on them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
busyychild Posted June 21, 2021 Share Posted June 21, 2021 (edited) Switch Combination SSA - 83161AG22A (for years 2008-2009) Cost: ~$225 at most Subaru online parts websites This is a full assembly that includes: - Steering Angle Sensor - Clock Spring - Turn / Wiper Levers - Mounting Base Below is photo of the complete assembly I replaced (not the new Switch Combination SSA that I bought, I forgot to take a photo of it before I swapped it in). This is considerably cheaper than buying the Clock Spring and Steering Angle Sensor separately. Took maybe 30 minutes in total to swap in. Note 1: The Clock Spring was already indexed, but I suggest you double check it. Note 2: The horn cord is part of the wire loom in the steering wheel itself. It is not included in this assembly. Link for reference (cheaper on other subaru parts websites): https://parts.subaru.com/a/Subaru__/49293911__6030046/SWITCH-COMBINATION-FORVDC/B13-832-02.html#83111 Edited June 21, 2021 by busyychild Link to comment Share on other sites More sharing options...
