Metal2You Posted August 5, 2008 Share Posted August 5, 2008 I hate to sound like a fool, but there is probably good reason for that Anyway, I just got Potenza RE-01's on new wheels delivered by Tire Rack and I don't know which direction the treads are supposed to be mounted. Does the swooping cut on the sides point forward, or backward. I'm guessing it should point forward as pictured here: http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+RE-01R Anybody know? Link to comment Share on other sites More sharing options...
johnAWD Posted August 5, 2008 Share Posted August 5, 2008 Check the directional arrows on the sidewall? Link to comment Share on other sites More sharing options...
Unfeign Posted August 5, 2008 Share Posted August 5, 2008 Yep, there will be an arrow on the sidewall with "Rotation" next to it, or possibly wording that says "This Side Out." http://www.tunerworks.ca/products/image/products/bs_potenza_re01r_ci2_l.jpg In taking a look, the direction should roll with the "arrows" foward. The channels down the middle and sipes going out help push any water out of the way, and give the performance. I have occassionally seen tires where the correct rotation is with the "arrows" going backward, but this is rare. Link to comment Share on other sites More sharing options...
Metal2You Posted August 5, 2008 Author Share Posted August 5, 2008 Yes, there is an arrow labeled "Rotation" pointing forward, resulting in the tread orientation in the picture. Thanks guys! Link to comment Share on other sites More sharing options...
meier motor sports Posted August 5, 2008 Share Posted August 5, 2008 the thread pattern on the top side of the tire (when mounted) should point towrds the front of the car. there is a arrow on the side of the tire. it will also indicate direction of rotation. the left side goes counter clockwise and the right goes clockwise Link to comment Share on other sites More sharing options...
ilh Posted August 5, 2008 Share Posted August 5, 2008 the left side goes counter clockwise and the right goes clockwise Only in the northern hemisphere. Link to comment Share on other sites More sharing options...
